Show Printable Version 26 Likes Search this Thread
06-21-2018, 09:21 AM   #76
reh321's Avatar
QuoteOriginally posted by iheiramo Quote
I've taken one shot on purpose with DA18-135 and K30 after ABF to test how it works and if I could use it to shoot against the sun. It didn't work quite as well as I hoped.
Is this a JPEG created by the camera??
06-21-2018, 09:36 AM   #77
QuoteOriginally posted by reh321 Quote
How long ago was the warranty repair? There is evidence that the aperture control units used by Pentax in to "repair" have the same kind of solenoid as is in the original unit, so they are just as likely to fail.
The repair came back 2/28/2016. It was there for months awaiting parts.
06-21-2018, 10:07 AM   #78
Unoriginal Poster
iheiramo's Avatar
No. DNG developed in Zoner photo studio, if I rmember correctly. I was switching to C1 about that time, so not really sure. Had to leave it a bit dark due to flare and PF.
06-24-2018, 04:50 AM   #79
reh321's Avatar
What happens if I try to use modern lenses at f/22 only?
I know that diffraction would be a factor, but how much?
Has anyone looked at DNG files? Is there actually something there if I process them enough??
For anyone "keeping score at home", as the broadcasters say.... My wife and I went on an outing yesterday. The K-30 performed flawlessly {mostly using the Sigma lens} after I exercised the aperture mechanism "until it worked" the night before, so this is still hypothetical thinking on my part.
06-24-2018, 12:40 PM   #80
LensBeginner's Avatar
Glad yo're still getting use out of it in spite of the failure
06-24-2018, 04:11 PM   #81
reh321's Avatar
QuoteOriginally posted by LensBeginner Quote
Thank you. I tried another this afternoon and it worked right first time. I may have to do something everyday to keep it working correctly.
06-24-2018, 07:40 PM   #82
bhbrake's Avatar
Mine is the opposite. It exposes a few images properly, and then after I start stopping down the aperture, it freaks out and over exposes images like crazy and I have to use full manual mode or adjust eh EV or shutter manually to correct the exposures. If it was not my backup, I would have sent it in for repair by now.
06-24-2018, 07:48 PM   #83
reh321's Avatar
QuoteOriginally posted by bhbrake Quote
When you use "full manual", how are you adjusting the aperture?
(1) on the lens via aperture ring
(2) from the body using rear e-dial
06-24-2018, 08:17 PM   #84
bhbrake's Avatar
I don't have an aperture ring on most of my lenses, so I use the e-dial. This does of course mean the aperture block has not completely failed as there is still an ability to control it electronically, but it doesn't communicate properly with the shutter release. If I shoot in shutter priority it selects the wrong aperture, and aperture priority selects the wrong shutter speed, so I have to end up setting the S, A,and ISO all manually to get a correct exposure.
06-26-2018, 10:08 AM   #85
reh321's Avatar
Pattern continued today - one dark one, followed by roughly a dozen good ones.
06-26-2018, 10:14 AM   #86
reh321's Avatar
Someone with more experience than me with this issue may need to respond. This doesn't sound like usual "aperture control issue", which consists only of camera body's inability to implement proper f-stop .... resulting in lens's going to smallest possible opening.
06-26-2018, 12:01 PM   #87
I had such a problem long time ago, with my K10D, until I was repaired under warrantee. Camera had lost control of the aperture. They exchanged not the motherboard, but a smaller, subordinated one. Not sur what is the correct name of that part. It seems it may happen not only with certain models.
Cheers - Klaus
06-26-2018, 12:33 PM   #88
SSGGeezer's Avatar
have you cleaned your lens and mount contacts and made sure they are not gunked up? Your intermittent issues sound like they could have other causes. Stevebrot is the forum member who is best at diagnosis via forum chat so i would PM him.
06-26-2018, 04:01 PM   #89
For those still wondering about more recent models I've not had this issue with either of two KS-2's or the K-70 with a few thousand shots each.. Here's hoping the chain stopped with the K-50.
06-26-2018, 04:33 PM   #90
Otis Memorial Pentaxian
clackers's Avatar
QuoteOriginally posted by gatorguy Quote
It's certainly been reported with the K-S2, Gatorguy.
The issue seems to be that solenoid used in the low end models. It can be not up to spec.
aperture, aperture block, block, camera, dslr, k-30, photography
Fix for the aperture motor failure? kernos Pentax DSLR Discussion 51 09-30-2017 12:08 PM
Survey with shutter count and aperture block or shutter failure. macman24054 Pentax K-30 & K-50 256 12-30-2016 11:47 PM
Aperture Block / Shutter Failure lakeshore Pentax DSLR Discussion 37 09-17-2016 05:24 AM
Is the SDM failure rate really that bad coreyhkh Pentax SLR Lens Discussion 108 07-21-2012 07:33 PM
How common is the K5 Shutter/mirror problem Rin Pentax K-5 & K-5 II 38 12-28-2011 05:35 PM
All times are GMT -7. The time now is 05:15 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
