09-27-2016, 12:54 PM   #1
Copying image files to mac from K-1 using Wi-Fi
I have finally got my Pentax K-1 body, and I am busy trying to figure out how to best use all the features.
There is one simple use case that I have not figured out how to do, or even if it possible at all to do:
The K-1 has Wi-Fi. To me is seems obvious that a network (like Wi-Fi) should be possible to use to make a copy of files (like the image files with the photos in the K-1).
I have been trying to figure out if I can use Wi-Fi to copy image files from the Pentax K-1 to my mac computer.
I have been able to get Wi-Fi network connection between the K-1 and the mac.
I have been able to copy image files from the K-1 to an iPad (with Image Sync).
I have been able to take the SD card from the K-1 and plug it into my mac to copy image files to my mac.
But I have not been able to figure out how to copy image files from the K-1 to my mac using Wi-Fi.
Does anyone know if it is possible to copy image files from the K-1 to a mac using Wi-Fi?
Does anyone know how to copy image files from the K-1 to a mac using Wi-Fi?
Thank you in advance for your advise!
---------- Post added 09-27-16 at 10:04 PM ----------
I just noticed that there was already a thread discussing this: https://www.pentaxforums.com/forums/190-pentax-k-1/326014-help-k-1-wi-fi.html
Had I only found this in the search before posting, I could have avoided to bother you all again with this. Sorry.
09-27-2016, 01:13 PM   #2
Doesnt fit my workflow.....
.....simply because i store my images on network drives. Once connected to the K1 wifi i naturally lose connnectivity to my network
09-27-2016, 01:50 PM   #3
It's not really possible. There's a user developed windows app that can do it (originally developed for the K-S2, link in our in depth review of that camera), but on a Mac you'd basically be limited to running Image Sync using an Android emulator.
You can also tether via USB
09-27-2016, 02:48 PM   #4
I had a look at the source code for this windows app. It does not look that complicated. The general idea is to transfer JSON encoded data using HTTP...
If I get a spare moment I might try to implement this as a mac application.
(Don't hold your breath. As a software professional and photography amateur, I usually do not have time for everything I find interesting...)
09-27-2016, 03:00 PM   #5
Yup, it looks like a simple interface. I might toy with a Java application that can deliver the same functionality- then the cross platform issue will be solved
09-27-2016, 06:43 PM   #6
How about Eye-Fi; isn't that available for Mac?
09-28-2016, 12:30 AM   #7
rechmbrs's Avatar
QuoteOriginally posted by TB-000 Quote
I believe that you can run Image Sync on MAC by using BlueStacks BlueStacks App Player for Mac | MacUpdate and Android like we have for PC.
RONC
camera, copy, dslr, figure, files, files to mac, image, image transfer, k-1, mac, mac from k-1, pentax, photography, wi-fi, wifi
Best Wi-Fi Solution for K-S2 (Transfer Images to PC) butangmucat Digital Processing, Software, and Printing 2 09-12-2016 02:39 PM
K-70 WI-FI remote experience PhotoNomad0 Pentax K-70 & KF 10 09-07-2016 04:23 AM
Help with K-1 Wi-Fi jva59 Pentax K-1 & K-1 II 8 07-17-2016 05:25 PM
New to Wi-Fi.....cannot connect to my tablet.....Simply lost. Dlanor Sekao Pentax K-1 & K-1 II 21 06-25-2016 10:29 AM
K-S2 wi-fi problem Wingincamera Pentax K-S1 & K-S2 2 08-21-2015 04:30 PM
All times are GMT -7. The time now is 09:08 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
