Originally posted by mattieyp3 Im simply looking to use the V6 transmitter and flash as triggers for my cameras. I want two cameras to take two simultaneous photos of the same moment in time. I would muzzle/snoot the flash to black it out. The challenge is figuring out if my camera will fire the transceiver at a sports acceptable shutter speed... 1/800th or faster.
As I understand it [Cactus v6 manual, p47], when you use the Cactus v6 as a remote shutter release, there are no shutter speed limitations. Plus if you set all your v6's to the same channel, everything connected to them might shoot simultaneously ...
If that doesn't work, you may also look into using relay mode on the v6 [p-49 of the v6 manual].
