11-05-2016, 10:14 AM   #1
Is there a smaller LI90-battery powered camera by Pentax?
I have a K-01 and a K5-iis, but have thought about getting a higher resolution camera like a K3 or K-70.
I am, however, stuck on the problem of carrying two sets of batteries. I guess it means I need a K3-ii.
Any suggestions?
Ron
11-05-2016, 10:43 AM   #2
How does the K-3 II solve your problem?
Are you often in situations where you run out of battery? In my experience the K-5 & K-3 II last a pretty long time on one battery. (Thought K-3 II not as long if you have the GPS on.)
11-05-2016, 10:52 AM   #3
For higher resolution than K-5/K-01
K-1 offers the same resolution on the sensor as my K5 (approximately). That's why I would consider either a K3 or a K-70.
K-70 uses a different battery so unless there is another body I'm not considering, I'll be aiming for a k3-ii (For future lens compatibility, too).
11-05-2016, 10:57 AM   #4
D1N0's Avatar
K-7 K-01 K-5 ((II(s)) K-3(II) K-1 All share the same battery D-li90. So you can use your batteries in them. K-30,50, 500 K-s1, K-s2, k-70 also share the same battery D-Li109.
---------- Post added 05-11-16 at 19:59 ----------
QuoteOriginally posted by squareeyes Quote
on pixel level... but you have more pixels so a much higher resolution. In that case you better get Pentax q. Much smaller pixels.
11-05-2016, 11:20 AM   #5
QuoteOriginally posted by D1N0 Quote
The only work I do that pays is copying original art. For this I use a 100mm K macro on my K5-ii. I figure that a bigger format would require that I move closer to fill the sensor and get the higher equivalent resolution. Moving closer, though, increases the effects of field curve and aberration. Currently I get to use the APS-C sweetspot and a comfortable working distance.
11-05-2016, 11:27 AM   #6
In that case, go for the K-3ii. The pixel shift might benefit your copywork.
11-05-2016, 12:55 PM   #7
D1N0's Avatar
You will get much better results for that with the K-1. Especially since you can use pixel shift. Macro lenses are known for having very little field curvature.
11-05-2016, 01:07 PM   #8
Pioneer's Avatar
No need for all of that. Just pick up an old flat field lens such as the Vivitar Series One 90-180 and you have no field curvature to concern yourself with. It is manual focus but that should not be an issue for your work.
Of course if you just "must" get a new camera than don't let me to get in the way.
11-05-2016, 01:28 PM   #9
UncleVanya's Avatar
The easy way to tell would be to move closer with your current Camera and simulate the distance change. You will only get a partial picture but you can test for field curvature. My guess is that the macro lens will still hold up.
11-07-2016, 07:23 AM   #10
Thanks all!
Now just waiting for an end-of-the-line K3-ii.
My K5-iis was $496 with grip. Sold the grip for 20% of the cost.
ROn
11-07-2016, 08:30 AM   #11
Otis Memorial Pentaxian
If your macro lens has field curvature, it is time to get a new macro lens. Ditto for aberrations. Unless the lens design is deficient, field curvature should be minimal (i.e. undetectable) at all working distances. BTW...field curvature is only one cause of reduced sharpness in the edges/corners. For art reproduction a lens should be sharp across the field, be flat field, and have very low distortion. Most true macro lenses have those as design goals and good ones deliver on that promise.
battery, camera, dslr, k-1, photography, pixels, resolution, share
There is a dead ant stuck on my camera's mirror. Outis Troubleshooting and Beginner Help 25 06-27-2016 09:22 PM
Is there any long lasting battery for the Pentax K-S2? denisguerra7 Troubleshooting and Beginner Help 13 09-08-2015 03:10 PM
Is there a auto-lens retraction setting for when camera is turned off? harioharima Pentax K-01 10 02-21-2013 05:27 PM
Why is the D-Li90 battery back-ordered? LeDave Pentax Camera and Field Accessories 2 12-30-2012 11:55 PM
is there a battery grip for a k100d lotekbmx Pentax Camera and Field Accessories 6 04-04-2009 02:57 PM
All times are GMT -7. The time now is 07:31 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
