So I bought the tamron 70-200 for my K-1 few weeks back, quite liked it and had some nice portraits done with it, and some sports. But, I've noticed that when I tried using it for landscapes, the left side of the lens, especially at the long end was always soft.
So I put it on a tripod, zoomed in to infinity, and tried shooting at different apertures. It's just always soft at the far left side of the frame. It's not a huge area, looks like about 6-7% of the entire image, but the right side is always the same sharpness as the center (or at least close to it, with wide open being softer obviously). So I thought lens was decentered, and sent it back to the shop I bought it from. They sent a replacement to me, it arrived today. So I tested it right away, and found the same problem, albeit seems a little better now. Soft far left at 200mm, right side is same as center. Thing is, I tried using other focal lengths, and it seems it's only a problem at the 200mm point, with 135, 100, 85 and 70 being consistently even across the frame (70mm seems a bit off too, but nowhere near as bad as 200mm, and I'm not as worried about it).
So, is the lens decentered, or it's just a quirk of this particular lens? I read that decentered lenses are soft at all focal lengths, is that true? Or is the lens miscalibrated at the long end? Please let me know what you guys think, I'm trying to figure out if I should send the lens back again and gamble on another copy, or ask the shop to send it to Tamron for calibration under warranty. Or just keep it and deal with the long end being like that? If anyone has a 70-200 tamron, can you please see if you experience the same thing @200mm or it's just my luck twice in a row..
Any input would be much appreciated!
PS: I think I slightly missed focus at 70mm 5.6, that's why image is a bit blurry. But again, mainly concerned about 200mm
I've put together a compilation of the focal lengths @2.8 and 5.6, can be viewed here (Taken with the new copy I've received today.): https://s11.postimg.org/w46jap0xv/70_200_sides.jpg
