11-17-2016, 11:30 AM   #1
Can I synch the K20 time and date with my PC clock?
I'd like my K20D to have the same time and date as my computer but it's tricky to do that manually.
Is it possible to do this with any of the Pentax or third-party software?
Thanks!
11-17-2016, 11:45 AM   #2
I'm not aware of synch capabilities. Maybe in the cameras with GPS?
You can set the time fairly accurately in the setup menu.
I find that if I want accurate timing for my images, I take a picture of a clock with accurate (or at least with a known offset) time display with the camera. You can then compare the camera time reported in the image EXIF data and the displayed clock time to get the camera time offset. For best accuracy, do this both before and after any time-critical pictures. You can then take out a simple camera clock drift.
I'm a bit of a time maven: when we do our radio astronomy experiments, we know the time to a few billionths of a second (nanoseconds) at each site, and after the fact, we can determine the relative time between radio telescopes to a few trillionths of a second (picoseconds),
11-17-2016, 11:59 AM   #3
QuoteOriginally posted by AstroDave Quote
That seems like an obvious and easy solution that never would have occurred to me. Thanks for that.
I take cemetery photos and I want to synch GPS data (recorded on my Vaio UX GPS receiver) with my photos' date and time stamp using a program called GeoSetter.
I suppose if I stand on each grave for a certain amount of time the recording should be fairly accurate with a certain window.
11-17-2016, 12:03 PM   #4
There are a few options.
The O-GPS1 unit supports GPS Time Sync, which will produce an extremely accurate timestamp.
You can sync up time in EXIF data after the fact, some people even do that with film.
You can sync up time with a subjective clock, then have software like Lightroom fix the time in post.
11-17-2016, 02:54 PM   #5
GPS isn't available for the K20D, but that's indeed a reliable solution.
11-17-2016, 03:05 PM   #6
Ah, good point. Support started with the K5, K-r and 645D for anyone else who's curious.
camera, clock, date, dslr, k20 time, pentax k20-d, photography, synch, synch the k20, time, time /date stamp, time and date
Date and time issues with Pentax K100D Super camera Tonytee Troubleshooting and Beginner Help 8 02-20-2016 06:59 PM
Original Q: Date and Time resets every time I charge the battery? Senduy Pentax Q 3 12-29-2014 12:47 AM
How long before I lose time and date settings? 6BQ5 Pentax K-30 & K-50 5 06-15-2013 07:35 AM
Optio E80 clock reset and won't honor [Date Adjustment] changes stoub Troubleshooting and Beginner Help 2 01-08-2012 11:27 AM
What I can do with my K5 and not with my K10D johnny_rino Pentax DSLR Discussion 4 02-06-2011 06:33 PM
All times are GMT -7. The time now is 11:19 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
