Originally posted by Professor Batty You could sacrifice a body cap to make an adapter. Here is a shot made with the 110 50mm f2.8 mounted on a piece of cardboard on a K-01, note the sharpness fall-off at the edges, probably due to curvature of field. It would be better stopped down with a washer. I tried it with the 18 mm and I only had about an inch distance between the front of the lens and the subject, the 24mm had a couple of inches. It works, sort of:
Thanks for posting the sample! I wonder if adding an aperture reducer would have cleared up some of the edge unsharpness?
While the price of the 18mm & 24mm 110s is appealing, perhaps the longer 110 lenses would have more flexibility for macro work--of course they would be in more competition with standard K-mount & m42 lenses that are very common in normal and short-telephoto lengths.
---------- Post added 11-23-16 at 10:52 AM ----------
Originally posted by dcshooter . . . . FWIW, the difference in FFD between the 110 and K mounts is 18mm, which when dealing with those tiny lenses is a pretty significant amount, in the case of the wider lenses, taller than the lens itself.
The popular mirrorless formats, on the other hand, are in the 17-20mm range, so they have up to a full cm of leeway between the two. The 110 lenses are stuck right in the middle of the two formats.
Fascinating. I wonder if anyone has tried nesting one back inside the camera to get the registration correct? Mirror would have to stay locked up, meaning no viewfinder. Might be able to do it in my old Zenit B, but then I'd be asking the lens to cover full-frame--darn!
