Originally posted by clarenceclose I had purchased (2) Minolta NP-400 batteries (Li-Ion, 7.4V, 1500 mAh) as spares for my K10D and had no problem with them until I tried continuous shooting.
fn button/up arrow/continuous shooting/OK/OK
then select subject and go for continuous shoot by holding down the shutter release.
2-3 shots max then get 'battery depleted' on LCD. Top LCD show graphic of depleted battery.
Turn camera off and back on and the top LCD shows graphic of full battery.
Do continuous shoot again, same problem, same fix.
Same problem with both batteries and they are definitely fully charged.
Put in Pentax battery that came with the camera (Li-Ion, 7.4V, 1650 mAh) do the above and can shoot until the card is full.
The Minolta spares work fine for one shutter release/one shot.
Anyone else have similar experience?
Defective batteries or just not hot enough to do the work?
I have a "clone" NP-400 from a UK on-line store (7dayshop), which cost around $12, and it works exactly the same as the Pentax original.
I charge them both in the supplied charger with no problems. I also have another charger (again from 7dayshop) which I can use in the car and again, no problems.
I would suggest that you return the NP-400's back to the original supplier if they are within warranty as I suspect they are not even up to the NP-400 spec. Sorry I can't be of more help.
