That's a trade-off. With the K1 you are getting sleek images even staying relax on ISO especially when using fast lenses and DoF isn't limiting, and ability to crop while keeping good IQ, all at the expense of burst rate, reach, size weight and cost. The K3 provides sharp images and x1.5 crop factor for macro and long lenses, smaller size, smaller cost, but as soon as exceeding ISO 400 resolution drops, and this is where the struggle comes into play, you need a faster lens on K3 because long lenses require faster shutter speed hence higher ISO in many situations. With Pentax the trouble is , beyond the DFA70200, the DFA150-450 is slower than the 300 f4, so except for AF, there is not benefit of shooting K1 + DFA150450 versus K3 + DA300 f4, and even the DA300 render better the OoF areas. My experience with K3+DA300 and K1 + DFA150-450 says that, except when there is plenty of time available (static subject), there is not difference but bokeh/color rendering. Equivalent works. Now , if Pentax would do a 500 f4 for the K1, that would bring back the K1 IQ advantage but at a significantly higher cost. For focal length up to 200mm, hand held, the K1 brings better IQ, and I suppose, if Ricoh release new fast primes for the K1, the gap in IQ between the K1 and K3 will still prevail.
