Originally posted by Edgar_in_Indy I'm kind of talking about the camera industry in general though, not just Pentax. As far as I know, no ILC camera is currently offered with an HD display.
And smartphones are basically handheld personal computers that are running operating systems, generating graphics, running apps, and receiving and broadcasting radio signals the entire time...things that cameras mostly don't have to worry about, and they still run HD resolutions...and many run resolutions much higher than HD. I'm simply not convinced that battery consumption is much of a factor here.
But yes, I would gladly pay a little extra for a true high-res LCD display.
The camera runs an OS (heck, you can even use a hacked version on some Canons) and generates graphics. And when the camera is on it's constantly powering the sensor.
But performing a mechanical operation - like screwdrive, IBIS, sensor cleaning, etc - those mechanical operations require a surge of power that is not similar to anything a smartphone does. Smartphones don't need to overcome mechanical inertia. It might be somewhat akin to looping 3dMark or running Doom on your phone constantly. And the popup flash also uses a bunch of power.
If you compare the CIPA battery life rating between the K-5 IIs and the K-3, all the incremental improvements in the K-3 (including a larger LCD) result in a 40% decrease in battery life rating.
Also consider that cameras are not maximized for optimal battery life the same way phones are.
With my K-5 II, I shoot manual focus exclusively. Even with a 3 year old battery I can still get 1000 shots, which is twice what I get with my K-01 shooting mostly AF. Not a great comparison, but I think that indicates that everything involved with AF uses a lot of battery power.
Even if a better LCD would reduce battery life by 10%, a camera maker won't do it, until somebody else does.
