02-16-2007, 03:32 PM   #1
K100D problem with LCD going dark
Hi, while I'm in the menu or fn session, my LCD screen will sometime just go blank before I'm finished with the session. I will have to push the menu or fn again to complete whatever changes that I was trying to make. I know this is a bug but not too bad that I will sent it back to Pentax for warranty. I did upgrade to the 1.02 firmware but did not fix this problem.
02-16-2007, 03:55 PM   #2
Alvin's Avatar
Welcome
While you are holding your camera fiddling with Fn or Menu, do you have your index finger near the shutter? The camera will often turn off the screen if you even brush the shutter button slightly, if you know what I mean.
The menus were created that way so that you don't miss any action. "Shooting priority" as Nikon would put it. But I don't know how Pentax would refer to it. If you are digging through the menu, and all of a sudden see something you don't want to miss, simply bring the camera up and fire. You don't have to fiddle with the camera to get out of the menu.
02-16-2007, 06:00 PM   #3
i think alvin is on the right track here.. a downside of the ability to intantly take pictures is probaby u lose the menue sometimes when u dont want to..
trog
02-16-2007, 07:26 PM   #4
QuoteOriginally posted by Alvin Quote
Welcome
No, I'm pretty sure I am not touching the shutter button. I just think I have a slight defect with my camera that I can live with. The problem is intermitent, sometime, the menu and fn work perfectly while other the screen just go blank within a few seconds, sometimes, it stays on for longer and than goes blank. I cannot detect a pattern of why it is happening.
02-17-2007, 05:28 AM   #5
Which lens?
This problem is know to pop up with eg Sigma 24-135/2.8-4.5 lens (non-rechipped) :-(
Best and happy shooting, JR (lucky me, mine is OK...)
02-17-2007, 05:43 AM   #6
Alvin's Avatar
QuoteOriginally posted by vanguy Quote
*examining my camera a couple hundred times*
Have you tried a reset? Menu > Setup > Reset
Perhaps a menu item that was changed?
I'm probing. Like I like to tinker, so I've got an itch to try different things. So forgive me if I come up with off the wall suggestions, like this:
Gentle shake of the camera for rattles (other than the sensor, which should be obvious)?
I can't think of anything else other than calling Pentax for some more support if the problem gets very annoying.
02-17-2007, 05:44 AM   #7
Alvin's Avatar
QuoteOriginally posted by Reps Quote
Never thought about that one...
Check your lens contacts? Remount the lens just to be certain.
Was the flash up or down?
LOL - I'll stop here.
02-17-2007, 08:06 AM   #8
xfraser's Avatar
My K100D does that when the batteries are getting low. When I recharge, the problem goes away.
02-17-2007, 10:43 AM   #9
I have not encountered this problem, I don't think it is a systemic problem addressable by a firmware update. (But I'm a photographer, not a techie or engineer so what do I know?)
The only time I have problems with the LCD screen going dark is when I have the CS-205 (I think that's the right model number) plugged in. Simple fix is to partially pull the plug when viewing the LCD.
02-17-2007, 01:55 PM   #10
jfdavis58's Avatar
Along these lines: tinkering and resetting. From time to time I find it incredibly helpfull to remove all batteries and allow the camera to 'rest for an hour or even overnight.
After replacing/reinstalling new batteries or newly charged batteries, perform a complete 'factory reset' via the main menu and also on any custom functions.
I've used this method to clear a number of problems on *ist-D, DL, K100 and K10. It seems to function a lot like defraging a PC after sorting My Documents and removing unused items--a general house cleaning sort of thing.
02-17-2007, 03:12 PM   #11
Tired all the suggestions with reset, taking out the batteries, shaking the camera . swearing at it but the Gramlin is still there. Oh well, might sent it back to Pentax if it gets worst but so far, I can live with it.
camera, dslr, fn, lcd, menu, photography, session
K-X LCD Problem - Will not display auburntigrs_1 Troubleshooting and Beginner Help 10 08-04-2011 07:29 AM
K10D Rear LCD Problem cajun0518 Troubleshooting and Beginner Help 6 07-08-2011 09:57 AM
Rear LCD Problem slpslee Pentax K-r 7 11-19-2010 03:19 PM
Pentax k100d Super back LCD display problem pisach Pentax DSLR Discussion 2 05-30-2010 10:31 PM
Dark Photo - LCD vs CRT Monitor Bubbabob Digital Processing, Software, and Printing 8 08-08-2008 09:31 PM
All times are GMT -7. The time now is 04:23 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
