Originally posted by amp
Thanks for the great responses. I wonder how big of a difference there will be between the kp and the k-3ii replacement? I guess autofocus performance and high ISO performance?
Taking a more conservative approach, I suspect it will be a blend of K-3II, KP, and K-1.
With the KP sensor.. same or slightly tweaked ISO performance. More along the lines of deeper buffer and faster burst rate. More AF points is a given. Probably same tethering as in K-1. Improved WIFI. Not a monumental jump from the K-3 II, but a significant enough one to make you upgrade over the K-3 II (should you have one).
Remember the jump from K-5 II to K-3 ? It was very sizable but not overwhelmingly more.
I think that is the same type of difference we'll see going from K-3 II to K-[whatever]
