Originally posted by JJJPhoto While I do shoot RAW from time to time (which makes the WB issue a non-issue most of the time) I cover enough weddings now that if I shot and archived everything in RAW I would have to start charging 2 times the price per wedding in order to cover the expense of all the hard drives I need to archive old images.
Then why not archive them in JPG after conversion?
Quote: In reality it means that much more processing time. Time is money ... and time is also life.
True, but if you use one of the batch processing software like Bibble, just two or three clicks for the whole lot, then go and have your dinner, and they would all be ready when you are back. This would be no different than JPG out of your camera where you don't have opportunity to tweak each one before JPG conversion.
Quote: If you have to work as fast as possible to capture once-in-a-lifetime moments and need to be able to use both flash/strobe and a wide range of available light ...
This is when RAW is valuable. You can go through the converted JPG files; if any once-in-a-lifetime shots were off WB, just go back to the RAW and adjust and convert again. After you are all done, then delete the RAW if you want to.
Yes, RAW->JPG adds some processing time, but it can be automated and unattended, because you do not have to tweak each one if you do not want to.
