Originally posted by niceshot Ok so ,a basic thing I learned today watching MIKENO62 ,was is this measure the travel of the helical before disassembling . Also Infinity is always considered the go to spot for reference when assembling. And always always count the revolutions and mark off the disconnections spot one every helical. The reason is really simple some lens do not afford you the opportunity to adjust Infinity focus, such as the 35mm3.5 Auto Takumar. There is no focus adjustment on the focus collar, so you be get it right first time out
Yep, marking or visually noting the points at which helicoids detach from one another was something I learned through trial and error. It took me many attempts to get my first lens back together so that it would focus to infinity, because I had no understanding that there were several positions at which the helicoids would interlock
Won't make that mistake again in a hurry!
One of the things that has become shockingly apparent to me while servicing my own Russian lenses is how badly some previous owners have treated them... squirting all sorts of thin lubricants / solvents into the mechanisms, cleaning inner optical surfaces with unsuitable materials or without adequate preparation and leaving fine scratches and smudges behind, bending levers and other components, stripping or breaking screws, damaging screw heads, or not tightening them properly etc.
I picked up a cosmetically mint Helios 44M-5 for peanuts because it was seized, wouldn't focus and had a loose focusing ring. I actually bought it to take apart and learn a bit about servicing, and didn't really care if it wasn't easily fixable. When I took it apart, three of the screws were apparently missing, but two of them were just loose inside the barrel
A previous owner must have started work on it and given up, then bodged putting it back together. The silly thing is, it only took me half an hour or so to take it apart properly, clean and re-lube it, and re-assemble (I had a spare screw to replace the one missing). It now works perfectly, takes great photos, and is one of the cleanest 44M-5's I've seen
