Originally posted by gatorguy The whole "bad AF" discussion is getting tedious IMHO. The OP isn't shooting football games from the sideline. For the type of photography he's doing, and in fact for the overwhelming majority of shots most of us take the autofocus of any of the newer Pentax camera's, ie KS2, K70, K3, K3II, K1, KP, is just fine and works very well.
I can't agree there, but I guess each to his own. Only K3, K3-II, K1 and KP have somewhat decent AF where with enough practice you can reasonably do anything but that would not be ideal for sports.
The KS2 and K70 match what the competion had 10 years ago. 2 few AF points except the center AF meaning any large apperture + composition is not reliable on top of no real possibility for any sort of tracking.
You can compensate with MF so you need fantastic eyes and to replace the view finder, LV but then even on K70 this is really slow! or tricks to compensate the camera short comings. Like when there was no AF... But then why spend money on AF lenses or modern camera at all ?
It is true the center AF point of theses bodies is quite good, not too big, optimized for fast lens, low light and reasonably fast, but that mean you either need to shoot larger than needed and crop to get decent composition and magnify the noise or focus and recompose so your are slow and introduce focus errors on large appertures... such kind of apperture that you may use more often indoor.
So yes if you use auto AF, target landscapes/scenes with f/8 - f/11, or if you just center AF point and recompose, yes K70 and KS2 AF if great. If you plan for anything better like using off center AF point, any kind of tracking then, theses AF module are clearly too limited.
If you want the typical setting of AFC + AF on the back button + selection of the AF point, this is a recipe for disaster. I started using that like 1 year ago, and funily since then my kepper rate and my composition drastically improved. But that with a K3.With the old AF module, the off center focus points are simply far too big. You ask to focus on the eyes, it may select the nose, some hair or whatever else.
Just a portrait with an off center AF point on the eye and a large apperture lens, even on a perfectly still scene and the AF of K70 or KS2 is lost if you don't go to live view.
