I would also recommend Bryan Peterson book. But before getting that. You would be better off using setting other than the SCN ones. That's fine for quick snap shots but to really learn this system, you need to understand what the camera is doing and seeing. Sunsets like the one you posted must be shot in manual in my opinion and with a tripod (no SR) or some other support like a picnic table etc. Some people have bean bags that they can stabilize the camera on almost anything.
But a sunset presents challenges to the camera. it tried to expose the foreground in your shot and blew out much of the sky. If you use spot metering off the sky and set the controls manually, you'll get a better result. Low ISO middle apertures and if you want to get higher saturation shots with more sky colours, then slightly underexpose the shot.
You will get more noise in the dark regions of the shot but that can be cleaned up in Noise Ninja (freeware).
Last as everyone says. A little careful sharpening is important for a good final result. As you know, this was my lens you have and it gave me very good results.
Although this was heavily processed. This shot came from your new lens:
and this
and finally
