Originally posted by pathdoc Three times I have turned it on tonight, and on each occasion it asked me to set the date and time.
The ist ds here has limited time ( compared to modern cameras) of memory hold up when the AA cells are removed or discharged.
I suggest to charge your 4 cells than check each one with a multimeter , should be around 1.60 + Volt
(Edit: ~ 1.35 + for Ray-O-Vac "Recharge") and all within a spread of 0.03 Volt.
As I recall, when the batteries are taken out too long, the date/time needs to be reset, but not the other user parameters ( not sure) .
Also the ist ds will discharge rapidly if you plug in the usb to up[load, and forget to unplug after a few minutes.
Apart from that , the ist ds here lasts about 2 months between charges.
Other check:
Set iso 1600 and take a photo of a uniformly lit subject like a speaker grille or dark wall etc.
Look for bright or colored vertical lines which might indicate a row with lost bucket brigade from the ccd.
Notes :
The ist d
L had a problem when they failed due to indicating low battery when the battery was actually OK.
I had two DL that bit the dust with this problem.
However this problem did not occur on either of the 2 ist ds I had.
the early model ist ds I had failed by the above line of bright pixels, followed by the often reported intermittent shutter wheel.
The one I still have was a late model from Mexico and it is still 100 % OK as far as I know.
Hope this helps you to keep your ist ds going.
regards,
