I have 2 K-01's, use them extensively with MF lenses and a screen Loupe, and actually like them. I also use and like Q/Q7. I don't use Sony at, though I've borrowed an A7r.
A K-01 was actually, virtually, a K-30 minus the mirror. The significant new hardware technology in K-30 and K-01 was the simplified and miniaturized IBIS array, using magnets on 2 sides rather than 4. Software improvement was the improved shutter sequence control (Close, Open-Close, Open) for LiveView.
I
did write
GOOD MILC from dSLR parts; good includes machine-optimized manufacturing techniques (the FABLED Sony 7-sub-assemblies and 26 screws story) as well as size and weight benefits (I know K-01 is one of the smallest digital cameras Pentax has made, though it doesn't look it).
I'm not convinced Pentax can make competitive CDAF AF and video using existing sourced components. If they obtain new component supplies / designs at least some of their EE catalog becomes obsoleted (adding a cost); and I'm not convinced the LCD signal is easily up featured to a hyper clean EVF either.
Ergo, I believe (as demonstrated by the responses to K-01) it is not possible to makemam'Good' MILC from dSLR parts.
Originally posted by dcshooter I'm not really sure how you can say that with a straight face. Just look at the K-01. Aside from the cosmetics, it was almost entirely a rehash of tech used in previous cameras. Most of the electronics are off-the-shelf and reused directly form the K-5 and other similar generation models. IBIS is recycled, mount recycled, shutter recycled, etc. Probably the most involved reengineering from a mechanical perspective was the popup flash.
Any FF K-02 would doubtlessly recycle tons of tech from the K-1. I, like the K-01, the exterior were all injection molded polycarb, tooling for that would be relatively trivial and inexpensive. On the electronics side, a new AF module would be preferable but not a dealbreaker. The EVF would add some complexity, but there are plenty of off-the-shelf solutions that could be incorporated relatively easily that could use the same signal path already used by the rear monitor. And with the reuse of existing components, fabbing the new circuit board and modifying existing programming for the camera would also be fairly trivial. If it kept the same flange focal distance as the rest of the K series, then mount geometries and electronics would be identical. Even with a tube solution like I discussed above, the electronics would still remain the same, and a new bayonet would be trivial to design and produce using modern CNC techniques.
Now of course, it would be a different story with lenses produced for a new mount, since those would require a considerable investment in new optical designs. The same could be said if Ricoh wanted to include bells and whistles like 4k video, since it would require both a new sensor and image processor.
However, as a relatively inexpensive boutique counterpart to the K-1 (as the K-01 was to the K-5), a K-02 would not necessarily require a huge capital investment.
