02-18-2007, 02:40 AM   #1
Battery indicator for DS
When I put in new batteries in my DDS, I find that the battery indicator flashes.
The manual says " the camera turns off after disp;aying a message" I never get a message.
it just happen with half used CRV3 batteries, which I know the state of.
it even does it with alkaline and recharageable Ni MH AA batteries.
today I put in lithium batteries adn had to reset the date and time.
any thoughts,
I can't wait for the K10D.
02-18-2007, 03:39 AM   #2
Mallee Boy's Avatar
Hi Russell,
Not sure. In the past I have used lithiums (AA & CRV3), which are good, but die with little or no notice.
I have switched to Eneloops which are fantastic. Here's a 'diary' of their use:
Bought Eneloops for DS in late Oct 2006, recharged them in mid Dec after some 500 shots (straight out of the packet...no charging)...still going today after another 600 shots and some flash use.
Bought a second set of Eneloops mid Dec for wifes DL, these are still going after 500 + shots, but battery indicator has dropped today whilst uploading to computer....but did not die.
Note: Both cameras can sit unused for weeks at a time.
Cheers
Grant
02-18-2007, 08:32 AM   #3
pentaxuser
Guest
If cleaning the battery compartment contacts does not help, then there may be a problem with the camera.
02-18-2007, 08:54 AM   #4
Alvin's Avatar
Pentaxuser beat me to this but I'll take it a step further. Try a soft, clean rubber eraser to clean the contacts - just a few light rubs to remove any corrosion if there is any. Use a pencil eraser (clean) to get the inside contacts. Blow it out with with a rocket blower before reinserting the batteries and give it a go.
02-18-2007, 08:04 PM   #5
Many thanks I will try the above advise.
Cheers
02-19-2007, 10:39 AM   #6
Hi Russel, I have a DS and have had no problems with it. I use CRV3's and other than the well known fact that they die with little warning, I have had no problem. I have taken many thousands of shots and replaced the CRV3's many times. I've never tracked how many shots I get per set of CRV3's but it's above 1000, I keep a spare set (or two) with me just in case. All I can do is reiterate Alvin's advice, except I'd use long Q tips and contact cleaner.
NaCl(Hope that helps)H2O
batteries, battery, battery indicator, camera, dslr, indicator, photography
Strange battery indicator behavior mikeSF Pentax K-5 & K-5 II 15 05-20-2012 06:30 PM
Pentax K-r Battery Indicator dqniel Pentax K-r 28 05-29-2011 07:37 PM
Battery Indicator dhoop Troubleshooting and Beginner Help 8 01-29-2011 07:39 AM
K-5 Battery Level Indicator kaikaiawaro Pentax K-5 & K-5 II 19 01-23-2011 04:43 AM
K-x Battery Level Indicator - Faulty? Rik Rabbit Pentax DSLR Discussion 11 01-03-2011 10:02 AM
All times are GMT -7. The time now is 06:55 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
