08-14-2008, 01:14 AM   #1
K10d and extension tubes
Hi to all,
I have a K10D with Sigma 17-70 lens and I recently bought tube extension to try out the macro field with my camera....of course the tubes were cheap(not the kenko kit), and they don't have any contacts to gain full access to the lens features. I have read about this stuff, but the thing is, even in full manual mode I cannot use any feature(the aperture settings would be a grate help).
My question is that because the lens don't have a manual aperture ring(it's auto) I can't use my extension tubes? the thing is that with them the aperture closes and I can't take any shot
I'm considering a DIY job to get some contacts in place....
Please tell me your experience with extension tubes, I really like to get this thing working
08-14-2008, 01:36 AM   #2
troywhite's Avatar
would be tough to do a DIY contacts job i'd say.
the only two choices I can see are
a) forking out for the kenko's
b) buying a cheap manual lens
for item (b) check out the market place forum on this site. There are heaps of oldies going for peanuts.
I have the cheapie extension tubes and use my old manual 50 f/1.7 on them no probs at all.
08-14-2008, 01:50 AM   #3
Indeed an oldie is a good idea, and to say a 50mm/f.1.7 is a good lens.
About the DIY project....I'll see what I can do, first I have to document a little more. Wouldn't want to brake something....
08-14-2008, 08:07 AM   #4
Tamron 70-300 has an aperture ring, works OK with extensions. A manual 50 works better though.
08-14-2008, 12:27 PM   #5
khardur's Avatar
and a manual 50 will have a much larger aperture than the 75-300 - much better for focusing, as you lose some light using the extension tubes.
I'd just get a manual 50 for relatively cheap. (even keh.com has them right now starting for around $70, and the f/1.4 versions for around $100)
08-17-2008, 03:19 PM   #6
When using extension tubes (or "fully manual lenses") you need to make sure that an (custom?) option called something with "Aperture Ring" is enabled.
I can't remember exactly what it is called, I borrowed a K10D (and I don't have my own Pentax, yet) a while back and when I mounted an old/fully manual lens, it wouldn't take any pictures. I remember reading something on the net about it and just went through the menus and found it...
After that it worked fine, except that the camera didn't showed/record the aperture.
It also cured the problems my friend had when using extension tubes (same symptom) (funny enough, the salesmen who soled him the camera didn't know about this).
This will of course not fix the problem with setting the aperture on that lens, but if you are lucky the "default" is the largest aperture (The aperture will still close when taking a picture, as that's an mechanical system [the extension tubes should transfer it out to the lens...])
Hope that helps! :?)
08-17-2008, 09:42 PM   #7
ebooks4pentax's Avatar
QuoteOriginally posted by andyar85 Quote
Hi to all,
You can buy a 1.4x teleconverter with all the contacts and remove the glass in the extender. It usually just uncrews. Voila, an extension tube with contacts.
aperture, camera, contacts, dslr, extension, k10d, lens, photography, tubes
For Sale - Sold: K10D, F 50mm 2.8 macro, P/KA extension tubes OrenMc Sold Items 3 06-29-2010 02:59 PM
Extension Tubes Barnster Pentax SLR Lens Discussion 9 11-04-2009 02:59 PM
Pentax K10D and extension tubes. troenaas Troubleshooting and Beginner Help 3 04-17-2009 08:30 PM
Extension Tubes kpfeifle Pentax Camera and Field Accessories 2 02-29-2008 12:24 PM
New-Old Extension Tubes Mike Cash Pentax Camera and Field Accessories 8 04-17-2007 04:11 AM
All times are GMT -7. The time now is 04:14 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
