Veteran Member Join Date: Jan 2007 Location: Conroe, TX USA | Error from 0.8.7
Andrea,
In testing 08.7, I took a shot, downloaded it, went back to refocus and got the listing at bottom. simfiles folder never allocated!
Not using bulb as you can see. Error looked like a remnant of download speedup which was unchecked.
Turned camera off and program shutdown. Turned camera back on, app opened but locked up. Had to reboot. Must run so test more later.
Unrelated to this, you should un-select image for download when download complete.
RONC
25-10-2017 05:50:58.106 DEBUG Application started
25-10-2017 05:50:58.607 DEBUG Deb.Splitter:1116
25-10-2017 05:50:58.644 INFO App Version: 0.8.7.0 ; Build: 7
25-10-2017 05:58:54.668 ERROR Error SetFocus: Could not find a part of the path 'C:\Users\Ronald\AppData\Local\Apps\2.0\KDD7E5XB.4RM\Y8HEHAV2.LYQ\wifi..tion_0000000000000000_0000.0008_84d70ebadfc399d7\simfiles\focus.txt'.
25-10-2017 05:58:54.684 INFO LV FOCUS: FOCUS NOT ACQUIRED. INFO: {"errCode": 200,
"errMsg": "OK",
"resoList": [ "1080x720", "720x480"],
"movieResoList": [ "1280x720", "720x404"],
"WBModeList": [ "auto", "multiAuto", "daylight", "shade", "cloud", "daylightFluorescent", "dayWhiteFluorescent", "coolWhiteFluorescent", "warmWhiteFluorescent", "tungsten", "cte", "manual1", "manual2", "manual3", "colorTemp1", "colorTemp2", "colorTemp3"],
"stillSizeList": [ "L3", "L2", "L1", "M3", "M2", "M1", "S3", "S2", "S1", "XS3", "XS2", "XS1"],
"movieSizeList": [ "FHD30p", "FHD25p", "FHD24p", "HD60p", "HD50p", "FHD60i", "FHD50i"],
"shootModeList": [ "single", "continuousH", "continuousM", "continuousL", "self12s", "self2s", "selfCotinuous", "remocon", "remocon3s", "remoconContinous", "bracket", "bracketSelf", "bracketRemocon", "multiExp", "multiExpContinuous", "multiExpSelf", "multiExpRemocon", "interval", "intervalSelf", "intervalRemocon", "intervalComp", "intervalCompSelf", "intervalCompRemocon", "intervalMovie", "intervalMovieSelf", "intervalMovieRemocon", "starstream", "starstreamSelf", "starstreamRemocon", "mirrorUp", "mirrorUpRemcon"],
"effectList": [ "cim_natural", "cim_bright", "cim_portrait", "cim_landscape", "cim_vibrant", "cim_radiant", "cim_muted", "cim_bleachBypass", "cim_reversal", "cim_monochrome", "cim_crossProcess", "cim_auto", "cim_flat"],
"filterList": ["off", "dfl_extractColor", "dfl_replaceColor", "dfl_toyCamera", "dfl_retro", "dfl_highContrast", "dfl_shading", "dfl_negaPosi", "dfl_solidMonoColor", "dfl_hardMonochrome", "hdr_auto", "hdr_mode1", "hdr_mode2", "hdr_mode3", "hdr_modeA"],
"exposureModeList": [ "P", "SV", "TV", "AV", "TAV", "M", "B", "X", "U1", "U2", "U3", "U4", "U5", "auto", "gps", "movie"],
"avList": [ "3.5", "4.0", "4.5", "5.0", "5.6", "6.3", "7.1", "8.0", "9.0", "10", "11", "13", "14", "16", "18", "20", "22"],
"tvList": [ "30.1", "25.1", "20.1", "15.1", "13.1", "10.1", "8.1", "6.1", "5.1", "4.1", "3.1", "25.10", "2.1", "16.10", "13.10", "1.1", "8.10", "6.10", "5.10", "4.10", "3.10", "1.4", "1.5", "1.6", "1.8", "1.10", "1.13", "1.15", "1.20", "1.25", "1.30", "1.40", "1.50", "1.60", "1.80", "1.100", "1.125", "1.160", "1.200", "1.250", "1.320", "1.400", "1.500", "1.640", "1.800", "1.1000", "1.1250", "1.1600", "1.2000", "1.2500", "1.3200", "1.4000", "1.5000", "1.6400", "1.8000"],
"svList": [],
"xvList": [ "+5.0", "+4.7", "+4.3", "+4.0", "+3.7", "+3.3", "+3.0", "+2.7", "+2.3", "+2.0", "+1.7", "+1.3", "+1.0", "+0.7", "+0.3", "0.0", "-0.3", "-0.7", "-1.0", "-1.3", "-1.7", "-2.0", "-2.3", "-2.7", "-3.0", "-3.3", "-3.7", "-4.0", "-4.3", "-4.7", "-5.0"],
"exposureModeOption": "",
"state": "idle",
"av": "3.5",
"tv": "1.15",
"sv": "6400",
"xv": "0.0",
"WBMode": "auto",
"shootMode": "single",
"exposureMode": "TAV",
"stillSize": "L3",
"movieSize": "FHD30p",
"effect": "cim_natural",
"filter": "off",
"timerExposure": false,
"focused": true,
"focusCenters": [[40,17]],
"focusEffectiveArea": [70,64],
"focusMode": "af",
"model": "PENTAX K-1",
"firmwareVersion": "01.42",
"channelList": [0,1,2,3,4,5,6,7,8,9,10,11],
"hot": false,
"battery": 66,
"stillFormatList": [ "jpeg", "dng", "rawdng"],
"storages" : [
{"name":"sd1",
"equipped": true,
"writable": true,
"available": true,
"active": true,
"format": "dng",
"reservePriority": "none",
"remain": 1572
, "dir": "109_1025",
"file": "_K1_0821.DNG"
{"name":"sd2",
"equipped": true,
"writable": true,
"available": true,
"active": true,
"format": "jpeg",
"remain": 2713
"channel": "6",
"slotMode": "separate",
"liveState": "idle"}
25-10-2017 05:59:04.684 DEBUG Shoot param: af=off ; bulb mode with seconds: False
25-10-2017 05:59:04.705 ERROR Error Shoot: Could not find a part of the path 'C:\Users\Ronald\AppData\Local\Apps\2.0\KDD7E5XB.4RM\Y8HEHAV2.LYQ\wifi..tion_0000000000000000_0000.0008_84d70ebadfc399d7\simfiles\shoot.txt'.
25-10-2017 05:59:04.705 ERROR Taking image: FAILED. ERROR:
25-10-2017 05:59:50.301 DEBUG Get Parameter
25-10-2017 05:59:50.310 ERROR Error GetParameter: Could not find a part of the path 'C:\Users\Ronald\AppData\Local\Apps\2.0\KDD7E5XB.4RM\Y8HEHAV2.LYQ\wifi..tion_0000000000000000_0000.0008_84d70ebadfc399d7\simfiles\parameter_k-70.txt'.
25-10-2017 05:59:50.320 ERROR Get Parameter success failed. ERROR:
25-10-2017 05:59:58.092 DEBUG Shoot param: af=off ; bulb mode with seconds: False
25-10-2017 05:59:58.092 ERROR Error Shoot: Could not find a part of the path 'C:\Users\Ronald\AppData\Local\Apps\2.0\KDD7E5XB.4RM\Y8HEHAV2.LYQ\wifi..tion_0000000000000000_0000.0008_84d70ebadfc399d7\simfiles\shoot.txt'.
25-10-2017 05:59:58.107 ERROR Taking image: FAILED. ERROR:
25-10-2017 06:00:38.398 DEBUG Shoot param: af=off ; bulb mode with seconds: False
25-10-2017 06:00:38.413 ERROR Error Shoot: Could not find a part of the path 'C:\Users\Ronald\AppData\Local\Apps\2.0\KDD7E5XB.4RM\Y8HEHAV2.LYQ\wifi..tion_0000000000000000_0000.0008_84d70ebadfc399d7\simfiles\shoot.txt'.
25-10-2017 06:00:38.413 ERROR Taking image: FAILED. ERROR:
