Originally posted by Andrea K
MP sent
Andrea,
My list of requests follows.
MUST FIX:
Icons still don't refresh coming back from photos tab
Seems that there is a time limit for focusing and will not take photo. Dark area or slow lens.
Location of focus should be marked on preview.
Wifi channel needs to be user changeable.
Warnings for battery low. Gong and red light. Same for SD cards.
Run using 645.
Documentation of installation and use. Seems to require administrative action to run. Doesn't open on camera wifi connection as you suggested it should.
REALLY WOULD BE USEFUL:
Make tabs larger.
Add ability to turn on Pixel Shift and other options. They work in Image Sync but have to be turned on. I couldn't turn on Pixel Shift on camera as Menu and Info were not usable in PWR. Shot in Pixel Shift mode. Should investigate delay in being able to record as is much longer than stand alone shooting. I downloaded one 200 mb PS file so no one needs to waste their time on that test. Too long for practical use.
DREAM:
Show whatever is on optical viewer or Live View screen in preview.
Be able to set most camera parameters via PWR.
Dark gray theme would be helpful in sunlight.
For items on list you will not work on please at least comment whether they are doable.
Thanks for help so far. Hopefully others will join the testing.
RONC
