Show Printable Version 51 Likes Search this Thread
09-15-2017, 07:37 AM   #106
Andrea K's Avatar
QuoteOriginally posted by DrawsACircle Quote
Now you mention SD card slot - could you make slot #1 default? It's not a huge issue, but for owners of 1 SD card slot cameras, it's a click less 😊
Please try v.0.7.6 because I changed some behavior to better support 1 SD card slot cameras.
Best Regards,
Andrea
09-15-2017, 09:14 AM   #107
Thanks Andrea for your hard work, I just installed .76. Using my Ks2 when a picture is taken it shows up in the left panel, but when I check live view and then take a picture, no picture appears in the left panel. When I click on the main panel picture with auto focus checked to refocus and then take a picture, the check mark changes and and shows auto focus off. I single click dose not always move the check mark, a double click usually moves the auto focus check from "auto" to "off".
Again Thanks
Hank
09-15-2017, 10:27 AM   #108
Andrea K's Avatar
Hi,
Thank you for your tests! I will send a PM to you.
About focus, when you click with LV ON I have to disable AF on shoot otherwise the camera will refocus when you press the shoot button.
I will debug the check control click problem.
Regards
09-15-2017, 01:50 PM   #109
Andrea K's Avatar
v.0.7.7 online.
Release notes:
1. support to DNG that didn't support thumb preview.
2. fixed sd cards preselection
Thank you to oneeyedhawk for the tests.
09-15-2017, 03:18 PM   #110
rechmbrs's Avatar
QuoteOriginally posted by Andrea K Quote
v.0.7.7 online.
Release notes:
JPG of DNG in thumb preview only downloads if sd2 is set so user has to change card setting between shot and attempt to download. At least should warn user. I have DNG to SD1 and jpgs to SD2 with K1.
Working on small screened laptop having Thumb Preview plus bug really limits viewing area. Can you make settings area shrink into left side for more user viewing space? I'd make Thumb preview either an option or shrinkable too.
RONC
09-16-2017, 12:10 AM   #111
v.0.7.7 online.
Release notes:
Ciao Andrea,
I installed 0.7.7.0:
Turn on the K1, turn on WIFI, connect laptop to camera's wifi, start 0.7.7.0
I tick the LV box in the SW and the camera start an endless "remote exposure" in intervals (I had to turn the camera off)
The same happens if the camera is in LV before I connect it... It looks like I can't use LV. The camera is set to single exposure in P mode...
The file list window is compressed (see attachment)... I don't seem to be able to expand it...
Ciao!!
Enzo
09-16-2017, 01:46 AM   #112
rechmbrs's Avatar
QuoteOriginally posted by vincenzomiceli Quote
Ciao Andrea,
Ciao!!
Enzo
Do you have one or two cards in the K 1? I test your setup with two cards and it worked. Will test with one if that is what causes it.
RONC
09-16-2017, 04:59 AM   #113
Best Regards,
Andrea
Thumbs Up Andrea
Tested with version 0.7.7.
09-16-2017, 05:42 AM   #114
rechmbrs's Avatar
Another go at 0.7.7 and I tested with one card (SD1). Works OK on mine laptop if I remember to set to record both DNG and JPG to SD1. Otherwise it was flaky. It seems to try to write and read SD2 and gives OK that I downloaded from there even though it is none existent. You might need to make a table for the user as to what settings go together.
Under INFO, SD1 RAWDN xxxx SD2 RAWDN xxxx both need more space for file type RAWDNG and the number xxxx. See below.
Regards,
RONC
09-16-2017, 01:51 PM   #115
QuoteOriginally posted by rechmbrs Quote
RONC
I have tried with both SD1 only and both SD1/2. I tried in P mode and in M mode. Here is a quick video...
Thx,
V.
09-18-2017, 05:53 AM   #116
rechmbrs's Avatar
Thx,
V.
20170916 163852 - YouTube
Is this different from earlier versions? If so, please check to see what you might have turned on since last good run. If not, Andrea needs to help. If first test, turn off things like the elevation correction etc. That you have to use the live view.
RONC
09-18-2017, 07:34 AM   #117
Andrea K's Avatar
Hi,
v 0.7.8.5 online, please re-test SD manage part.
RAWDNG?!? How have you set picture format and SD?
Ciao Andrea,
What version of Windows? Also check that you really have the v0.7.7.0 (or now 0.7.8.5) installed (Help->About).
Please, retry and provide me the log: Help -> Save Log (new feature)
Many thanks!
09-19-2017, 02:12 PM   #118
Many thanks!
Yes, I'm on Windows 10. I was using 0.7.7.0. I installed 0.7.8.5 and I have the same issue, the moment I click the LV button in the software, the camera starts shooting with intervals of a second or so until I unclick the LV button. I have attached the log.
Ciao,
Enzo
09-19-2017, 03:10 PM   #119
Andrea K's Avatar
What is your SD cards configuration and setup? You have any card in slot 2?
Also try to upgrade firmware and retry.
Thank you
09-20-2017, 01:06 AM   #120
Andrea K's Avatar
v 0.7.8.6 online.
Release notes.
1. more verbose log
2. little interface modification to show 6 digits file formats
3. more support to RAWDNG and RAWPEF formats
Vincenzo, try to update the k-1 firmware please.
Best Regards
application, base, camera, corner, dslr, fps, image, information, k-1, lv, pc, pentax, pentax wifi, photography, photos, program, ricoh, screen, sec, settings, software, sync, tab, tests, time, version, wifi
EZ Share Wifi SD card on Pentax K-X CLG Pentax Camera and Field Accessories 12 01-09-2020 11:23 AM
Pentax K1 WiFi??? englishphotographer Pentax K-1 & K-1 II 16 06-20-2018 06:23 PM
K-1 not connecting to my phone via wifi geomez Pentax K-1 & K-1 II 24 11-27-2017 01:45 AM
For Sale - Sold: Pentax K3ii + Battery Grip + wifi card + additional batteries + extras.. tomO2013 Sold Items 4 11-17-2016 01:05 AM
K-S2 wifi vs K-1 wifi robtcorl Pentax K-S1 & K-S2 7 04-03-2016 09:54 AM
All times are GMT -7. The time now is 05:43 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
