If putting money forward for in-camera SR, I agree with others in saying why not go for a model that will present other meaningful upgrades over what you have as well? You do not sound like you are especially into video use. The Pentax line is more oriented for still photography, so Canon, Nikon, and others have models that can do better in that department, although Pentax can give a usably decent video clip.
Otherwise, the current Pentax line has much more advanced features in the most affordable class. All have weather sealing (WR), a premium pro-style glass pentaprism viewfinder with 100% field of view and 95x magnification, 2-dial thumb and finger controls, and much more. The basic kit lenses also come with WR. With other brands, such features are only found in higher-end models in the $1,000 range for a body, and around that for a lens. Your Canon, for instance, only has a dimmer pentamirror VF with around 95% coverage and 82x magnification, and the latest Canon affordable models are likewise.
I'd say don't write off the Pentax K-S2 for a low-priced deal, especially if you shoot mostly JPEG images. The RAW is also very good, but the advancements for the K-70 are mainly 14 bit RAW for better color gradations instead of the more common 12 bit, better low-noise performance especially over ISO 3200, and the new Pixel Shift technology for images shot with tripod.
The Pentax deals now available for what you are getting are terrific. I just checked prices at B&H, which are probably similar to Amazon and elsewhere. Prices vary according to color. Lately, the base price for a black K-S2 body has been around $500. I see a kit available for $536 with the unique tiny DA-L 18-50mm lens. For only $36 you also get a lens that separately sells for around $300! The lens also has WR, and when retracted for storage, which being a bit fiddly takes a little getting used to, it is the smallest zoom lens for APS-C in the industry! It has fast, quiet, and sure AF performance, and very good image quality, especially if stopped down a click.
The K-70 does not yet come with that lens in a kit deal. Its base body price for black is about $600. For $270 more you can get it with the very useful DA 18-135mm kit, a lens which separately sells for over $470 and worth it! The lens is exceptionally well-built, has WR, compact for its zoom range, fast and sure quiet AF, and very good image quality. Getting back to the K-S2, if you don't mind one having an orange bottom plate, there's a kit available with the DA 18-135mm for only $699, which means you're getting a $475 lens for $199!
I always recommend, upon getting your camera be sure to set the sharpness to "fine" in the custom menu. For the 20MP K-S2, I also increase sharpness by +1 over default. With the 24MP models, so far I leave sharpness degree at default but still apply the "fine" setting. And do check back regarding the exclusive Pentax Hyper System, where when shooting in Program Mode and you desire a different aperture or shutter speed, you can just select it using the thumb or finger dial and the camera just does it (!) converting to Av or Tv operation until you hit the green button to return to full P mode, or turn off the camera. In (Hyper) Manual mode, the green button will set instant exposure, great for spot metering around a scene quickly.
