Quote: Your example, where the FF camera needs to shut down an extra stop, assumes that more depth of field was required. Why make that assumption? We're not conducting an experiment where we must get identical images from two different camera formats. What we're focusing on right now is trying to get the cleanest images at high ISO.
If the image doesn't matter then why even take the image? Taking a high ISO image has no value in it's own right.
Originally posted by Edgar_in_Indy It could be that either camera would have enough DOF at f4, or it could just as easily be the reverse, where the photographer would prefer less DOF for the given image, in which case the APS-C user is just SOL at some point. But that was not the point of the discussion.
If the FF is good enough at ƒ4, then APS-c is good enough at ƒ2.8. The FF has a one stop advantage if the lens is wide open, narrower depth of field but a 1 stop noise advantage. And that's a real advantage. But it's only an advantage shooting wide open. Any other time the same results can be achieved with either system. And the APS_c doesn't camera does,t really affect that at the long end. Generally diffraction means you get an extra stop with an FF body, although only for bodies with the same MP. Once you close your FF a stop, anything FF can do APS-c can do. SO do you really want to buy an FF system for better high ISO performance with the lens wide open? It's a pretty small window of opportunity. For that you trade the extra reach of the APS-c camera with the same lens. There's no free lunch.
Quote: Try putting the same total light as an image taken a FF at iso 100 F32 1/125sec on a cropped body.
At ƒ32 you have serious diffraction problems on either FF or APS-c but worse on APS-c. Not so much on 4x5 or 8x10 film. On 8x10 film even ƒ64 is still pretty good.
But at the long end of the scale say in your example
-FF-__ ISO 100 ƒ32. 1/125
APS-c ISO 100 ƒ32 1/125
It's a trade off, more total light (less noise) for more DoF. You decide which is more important and you take your pick. Which system you use depends on which advantage you want. However it's not a clean trade. The FF sensor is going to handle the diffraction a bit better, so you'd really have to want that depth of field for it to be worth while before going to APS_c.
But we are talking about the extreme ends of the lens range, and there are good reasons for not going there, 99% of the time. So we are discussing not the everyday shooting, but the extreme cases. Straight up, there's no sense in giving theoretical importance to things you don't very often do.
Same image, same total light. I'm not seeing where you are going with this. At that end the DOF on the APS-c gives the APS-c the advantage.
This if course would be pretty moot for K-1 users. Technological processing advantages have increased the ISO of the K-1 to nearly a 2 stop advantage, meaning the only real advantage to the K-3 is reach in good light.
