Originally posted by Chrisworld
*istDL with cheap custom ~$9 pinhole body cap.
Not exactly a pretty image (and the pinhole cap quality is not great and really dirty) but looks really creepy.
I enjoy the results of pinhole photography and don't do nearly enough of it. Finding the "right subject" can be part of the battle ... you managed to succeed here
The dust-spots you see are the result of dust on the sensor, as you're probably aware. They can be easily (mostly) removed by using an appropriate filter/plug-in in your image editor of choice.
I don't believe the
*ist DL has "Digital Preview" (neither does my
*istDS), so a bit of "chimping" with the histogram enabled can help with exposure. You can always delete the ones that don't work if card-space is an issue.
I assume you're using a tripod or similar support
Enjoy
