Originally posted by kypfer I enjoy the results of pinhole photography and don't do nearly enough of it. Finding the "right subject" can be part of the battle ... you managed to succeed here
The dust-spots you see are the result of dust on the sensor, as you're probably aware. They can be easily (mostly) removed by using an appropriate filter/plug-in in your image editor of choice.
I don't believe the
*ist DL has "Digital Preview" (neither does my
*istDS), so a bit of "chimping" with the histogram enabled can help with exposure. You can always delete the ones that don't work if card-space is an issue.
I assume you're using a tripod or similar support
Enjoy
I actually didn’t use a tripod, just winged it. Stood still, had camera hanging from my neck via strap.
As for the dust, I actually clean the sensor regularly and it looks perfectly clean to the eye, and every other image without this lens looks fine so I’m not sure what’s going on there. Like the images are virtually flawless with other lenses.
Interestingly, RAW hides the hundreds of dead pixels on this sensor. If I shoot in JPEG the image looks bad, lots of colorful dots spread everywhere. I can quick look PEF on my Mac and when you zoom in it switches from JPG preview to raw and the image suddenly looks much better. Can’t figure out that one, perhaps the raw blends the pixels and error corrects?
