Originally posted by lotech So this type of flash is not suitable for primary flash, they are meant for slaves right ?
Not completely sure I understand what you mean. I use all off camera flash triggered by radio. In studio I use two monolights plus a Nikon SB-26 all triggered by Cactus V5 and v6 triggers. Out of the studio I use a combination of the Nikon, the Cactus RF60 flash and several old Pentax AF200T flashes again all triggered by the Cactus RF triggers.
If you mean one flash on the camera that is then triggering additional off camera flashes, then yes those are called slaves. That is a standard P-TTL setup where the master flash controls the slaves with optical pre-flashes. But you need a P_TTL flash that is capable of operating in master mode, not all can.
You can also set your 'slave' flashes to fire on receipt of the main flash burst. But this only works in manual, not P-TTL. In P-TTL the master will fire a "preflash" to determine the exposure and this sets off the slaves. Some slaves are sophisticated enough to ignore the preflash, but I never had much luck with it. I prefer all manual. set things up the way you want, adjust as needed. Simple.
Sorry, I am not really up on TTL or P-TTL, I use all manual flash. There are several really good flash folks on this forum hopefully one will stop by and help.
