Originally posted by jjnevis I have a fairly new K50 that has developed the dreaded "black image" disease - aka intermittent aperture actuator failure. I'm going to have a go at fixing it, but I'm pretty disappointed in Pentax, since I had invested in brand (2 other lenses and flash) specifically because of good reputation.
The K-50 is still a very capable camera, with the aperture block being its only major issue. Sadly, when if it does go (as it has for you) it's a pretty big problem.
If the camera is still fairly new, check to see what your warranty options are. If you can get the camera replaced or repaired under warranty you can save your 600 pounds for another day.
Originally posted by jjnevis Now, I know things fail so I need to get over it, but what should be my way forward? I want to move on (and up a bit) and was thinking of getting a K3 (seems very well built), but it looks like that model is fairly old and might not be being made anymore? What other model should I consider for mainly hobbyist stills of all kinds? Budget approx £600 (inc preowned)
A second hand K-3 is a very good value option. Lots of camera for your pound. A new K-3II is also a good value way to go, being at the end of its sales life (due for replacement with a new model) it is going at a good discount, but it might be just out of your budget.
The K-70 is the other major option. It occupies the same place in the lineup as the K-50, but has some pretty nice tech updates to make it a substantial improvement. As I understand it also uses a different aperture motor, to address the failure problem you have already experienced.
