07-07-2017, 09:13 AM   #1
Helios 1984's Avatar
I screwed big time - Broken viewfinder : (
I set my K-50 on my tripod but failed to fully deploy the legs... before I knew it the whole thing tipped over. The back of the camera hit a flower pot and the viewfinder shattered (I should consider myself lucky that the LCD survived without a scratch)
07-07-2017, 09:20 AM   #2
danielchtong's Avatar
QuoteOriginally posted by Helios 1984 Quote
Try to get a quote for replacing it.
Meanwhile you can only use LV
07-07-2017, 09:24 AM   #3
smf
smf's Avatar
I'm sorry your camera was damaged, but thanks very much for your post. It will prompt me -- and I assume others -- to check deployment of tripod legs.
Best wishes.
07-07-2017, 09:30 AM   #4
Sorry to hear that. I've been saved a few times by the rule of only ever setting up with my camera while still attached to me via my neck strap. Tend then to only take of the strap on the rare occasions. A pain, yes, but it's saved me a few large bills.
07-07-2017, 09:53 AM - 1 Like   #5
I'm one lucky Pentaxian, only the protective glass broke. I removed the shattered pieces with precision tweezers and everything is 98% fine. I'm not mad, it's a lesson that I will remember
07-07-2017, 10:02 AM   #6
Otis Memorial Pentaxian
The wicked tripod demon has its way with yet another innocent camera.
I have had close calls with both unsecured legs (camera went sliding past in my peripheral vision and managed to catch it as it went by) and loose QR plates (found out as I went to remove camera), but only one full-on fail. Some twist-type legs are finicky about the extend/twist sequence. I got out of sequence with when using my Giottos MT 9360 with 4x5 view camera mounted and came just short of having both camera and tripod pitch off a footbridge into a ravine. A railing stopped both with damage limited to a bit of dented teak (rear standard on camera) and a scratch on the tripod.
07-07-2017, 10:23 AM   #7
Now add the Pentax (can't recall the code)magnifying viewfinder, perhaps ?
07-07-2017, 10:52 AM   #8
QuoteOriginally posted by BarryE Quote
Pentax O-ME53 ?
07-07-2017, 10:59 AM   #9
Not a Number's Avatar
Weather sealing may be compromised.
I don't know if the K-30 parts will fit but you can give it a try.
DSLR Camera Parts
This is the same guy that does the aperture repair on the K-30/50.
07-07-2017, 11:01 AM   #10
Yup that's what I was thinking of. I find them useful for manual focusing too ...
07-07-2017, 12:36 PM   #11
QuoteOriginally posted by dcshooter Quote
Came here to say the same thing. Avoid rainy day shots.
My old lenses ain't weather sealed so I never shoot under the rain, thanks for the advice tho :-)
07-07-2017, 12:42 PM   #12
Maybe if rainy shoots are important the extra protection of the O-ME53 may help with line of silicon/acrylic sealer to seal it. A bit of a bodge, perhaps, but it's not going to get into the internals, and could be easily (enough) picked off. I'd be tempted as I shoot in the rain a lot ...
07-07-2017, 12:58 PM   #13
There is also the rain cover option.
---------- Post added 07-07-17 at 01:45 PM ----------
DSLR Camera Parts
I watched a video on youtube, it doesn't seem overly complicated to replace and the part is way less expensive than what I anticipated.
Thanks for your reply.
07-07-2017, 09:46 PM   #14
Could be worse. A friend had this happen with his Canon and a 300mm 2.8 attached. Damaged the lens and ripped the front off the camera. Glad it looks easy to deal with.
07-07-2017, 10:02 PM   #15
Yes, print services and used camera parts are his main business.
camera, dslr, photography, rain, time broken viewfinder, viewfinder
Question Getting sick of screwed-up PF home page Paul the Sunman Site Suggestions and Help 4 11-10-2016 01:39 PM
I screwed up. K3 grip wont come off UMDTERPS Troubleshooting and Beginner Help 26 07-19-2015 06:31 AM
Broken DA* 50-135mm... Screwed $800? GLXLR Pentax SLR Lens Discussion 24 12-18-2011 08:30 AM
I screwed my K100D today little laker Post Your Photos! 17 06-17-2008 04:28 AM
Screwed up 1000 ISO Best Fix ? daacon Digital Processing, Software, and Printing 8 08-27-2007 12:58 PM
All times are GMT -7. The time now is 06:22 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
