Originally posted by Ketsuppi11 You don't think that Carl Zeiss 50mm Makro-Planar and DFA 100mm WR are good FF lenses?
There really no bad macro primes but they usually quite average in rendering for non macro/proxy shots. Oh, usually macro are extremely sharp, with flat field and constrasty but that also why they don't render people as well for example a portrait prime lens. They are said to be then great for landscapes but from experience I still prefer the FA ltds to the the Pentax macro lenses I tried for that.
Sure, they would beat anything else for macro but I don't get the point of FF for macro. The subjects are small usually, and the focal length doesn't change. The same subject fill the frame less on FF than on APSC. A 24MP APSC give an addiitional 1.3X reach vs 15MP of K1 for the APSC crop... And once the same surface for the subject there no benefit of FF vs APSC. If anything the best Pentax camera for low light for the same APSC surface is the KP. Not the K1.
Actually I think that none of the lenses the OP have fully leverage the FF. FA31 become a WA and less likely to be used with significant bokeh where it shine the most. On FF more modest lenses like the FA28 or FA35 (to keep the FA rendering) would be more often than not undistinguishable from the FA31 for picture quality and rendering on an FF. The 2 macro lenses are doing a fine job on APSC and do not benefit that much of FF for macro. For non macro/proxy there better lenses out there and if you are in research of improved gear for better picture quality, you'd want them. The APSC zoom would work in crop only.
And again let's not forget the crop difference. None of the lenses the OP currently have would be used for the same as before except maybe the DFA100 for portraiture. But already the type of portrait and rendering would be quite different. If the choice of focal length of the prime was not random, the OP might want to change it prime setup entirely in the long run.
