Originally posted by derelict What confuses me though is lenses on the APSC sensors. I take the focal length and multiple by 1.5 and get the new focal field of view, correct? Or do I take the 28mm of my K series lense and divide by 1.5 to get the new field of view equivalence?
Here is how it works. All lenses have a focal length. This is a lens property and has nothing to do with the camera. The typical "film" is 35mm on the long side. But "crop cameras" have smaller sensor, so it is like cutting off the corners of that film. This makes the illusion that the Angle of view is different, less wide. Micro 4/3 and Q are even smaller than APSC. This is why smaller formats usually have lenes that are 5.6mm, 12mm... You can't find 5.6mm lens on 35mm Full frame, it would be insanely fisheye. But on a Pentax Q, its a sensible focal length for
that sensor size.
All 50mm lenses will give you the same Field of view angle
on a given camera. Its when you go from one sensor format to another that changes the apparent magnification/FoV.
This mean that if you like the Field of view of a 50mm lens on your Full frame/film camera, you need a 35mm lens on your APSC camera (35mm*1,5=52,3 which is about the same as 50). But you can still use FF lenses on APSC sensor camera. This is why old lenses like K or M or A or F or FA series all work fine on APSC cameras today.
Originally posted by derelict I could spend the same amount of money and get a pro level zoom for my Olympus which would increase the likelihood of my carrying it around or buy an APSC K mount body and reduce the need to carry two platforms around.
I would always avoid having more than one system. Its confusing and expensive. You can get camera like Pentax K-S1 and it is super small. Add lenses like DA 21mm, DA 40mm, DA 70mm or DA 20-40mm limited and you have a great kit with lots of character, really great image quality, DSLR controls, in a really small package. Pentax gear is pretty compact compared to others, and it is reasonably priced.
Another advantage of Pentax K is that it can mount pretty much any Kmount lens without need of adapter. So you can put that K 28mm on K10D or K-S1 or K-3 or even K-1. On K-1 it will look the same as on film (perhaps more resolution), but on APSC cameras it will not look as wide.
