Sounds good!
Originally posted by c.perkins Have it set to RAW+ and have Lightroom 6 for post processing.
Seems right. Just set up a good default profile. By that I mean the NR (20-25 at low ISOs, I just do it by hand for the extreme ISO values), sharpening (25-50), camera colour profile (Embedded or find a custom one online; I don't like Adobe standard), lens profiles if you want. And of course bump the contrast and vibrance a little; pretty much all raw files need that. And you're set!
Originally posted by c.perkins Any tips for using a manual focus "A" lens will be appreciated or anything else to be aware of with the K7.
Push the button on aperture ring, set it to A, and leave it in A forever. Focus has to be done by hand, just look through viewfinder. I'm not sure whether that camera has focus confirm for manual lenses. Its a little green hexagon in the viewfinder that lights up when AF has been locked. You can also search for Catch in focus and experiment with that method. You just enable CiF, turn on AF on camera body (turn on focus priority, not shutter priority; use the AF mode that is listed in camera's manual, AF.S probably), and then hold the shutter as you slowly turn the focus ring. As focus locks, shutter will start firing.
