Originally posted by gerardbaron How do you like the sharpness?
Samyang 14mm f 2.8 is sold under many names like Walimex, Rokinon, Bower and others. They are all esentially the same lens. The lens comes in various mounts and they don't all have the same stuff. For example, Nikon mount needs a chip (older version of the 14mm did not have that), Canon is different yet again.. Pentax K-mount has A on aperture ring. It works normally with auto aperture. I use it all the the time (Samyang version).
It is a sharp lens, very good. Has some downsides, mainly problems with decentering in the earlier batches of the lens. So do some tests to see if your lens is decentered or working normally. If you get a good copy, you will be very happy with it. I recommend you learn Zone focusing and Hyperfocal focusing. The distance scale on that lens is often miscalibrated. There are youtube videos and blog posts about how to fix that easily yourself. I never fixed it on mine, I just learned how much off the distance scale is. If you shoot above appx. f6.3 your DoF will be really massive and focusing will not be a big issue.
