Originally posted by maltfalc 4 slots each only recording every fourth photo would quadruple write speed with no need for any additional software, and if space becomes an issue, micro sd.
Well, it would increase speed to a certain degree: The theoretical max speed would only be used after you've taken more than four shots (since one pic is only written to one card, but I agree, it's mostly only then more speed is needed), and even then resulting in a top speed of 4x max card speed. If the bus is upgraded to the max and using top-performance cards it would still result in a max speed of 4*90mb/s=360mb/s, which is only a bit more than about half of the max data production rate for the K1 and the buffer could still fill up. Sure we could add 8 cards then instead to write faster than you can shoot but with 8 cards it starts getting ridiculous =), that's why I favored the SSD - you get those speeds with a couple of storage chips.
So I agree 4 cards would be a (large?) improvement over today (aside from somewhat more hassle when offloading 4 cards since many here seems to prefer that way to offload the data), but for my part I'd still prefer an SSD-version due to the advantages I mentioned above, unlimited buffer, and if paired with usb 3.1 or later, it could be read/offloaded at 1Gb/s, while the cards would still have the max 4*90mb/s and/or having to eject 4 of them depending on the camera bus speed or prefering to offload by cardreader.
