Originally posted by Medex could you explain, please, how to use "Link AE to AF point" properly and in what situations? Thank you
You would have to ask
The short answer is that if you are not sure, it is probably best not to use this setting. The assumption is that the point of focus should also be the basis for exposure and that this is always a good thing. The devil, however, is in the details.
Originally posted by jpipg I am also curious about this, I kind of assumed it was only relevant for spot (Centre) metering mode
That is a big one and the first that comes to my mind for cases where the lighting on the subject is significantly different than the rest of the frame.
Here are the points to consider:
- How much control does one have over the AF point?
- Does not work well if using a "focus and reframe" technique.
- How certain is one that having exposure based on that point desirable?
- How well does the current meter mode (evaluative, center-weighted, or spot) work with the feature?
- Is AE itself appropriate to the subject? Ditto for AF...
- How much exposure compensation might be appropriate? The meter may place exposure to middle gray, which may be too dark.
- Is there another way to accomplish the same goal?
The feature truly is a fairly blunt tool and one that may be hard to control. Results with regular evaluative metering may be better. FWIW, my approach to club or stage lighting has been to use manual exposure.
