Originally posted by DJey I'm in in M-mode with AF using kit lens.. It's in the midlle of the day and the focus confirm was there.. I didn't use the flash or timer too.. Do you think I should let the service center take a look at my camera body?
If you're saying the shutter takes a second to fire after the focus confirm comes on, then yes, that sounds like something is wrong. I'm still at least a little suspicious that there is some other setting we aren't thinking of that is causing this, but I'm stumped.
