09-03-2017, 03:37 AM   #16
Thanks for all the replies guys... All points noted.
09-03-2017, 07:56 AM   #17
seagas's Avatar
I just upgraded from my K-s2 to the KP, while not a huge difference, it is noticeable especially on low light photos and the AF is much better.
09-03-2017, 08:47 AM - 1 Like   #18
normhead's Avatar
QuoteOriginally posted by seagas Quote
Looking at your avatar seagas, if i ever start a successful company, I'm going to name you CEO. You look much more like a person who should be running a company than i do.
09-03-2017, 12:55 PM - 1 Like   #19
You will get a noticeable improvement for low-light/higher ISO low-noise performance with the KP. I've owned one since May. You will also have superior fine detail resolution by way of the 24mp sensor and Prime IV engine with accelerator, and the fact that you will no longer have the AA filter, and you have access to the advanced pixel-shift resolution. I noticed some improvement in fine detail when going from my K-5 to the K-5 IIs, both of which have a 16mp sensor similar to your K-30. The KP is still somewhat better yet, as well as in metering, and AF. A great camera, and very well built.
The degree of improvement will of course also depend on what lenses you will be using, as far as fine detail. And, always set your sharpening in the custom image menu to +1 (already default in the "Bright" category) then add the "F" for "Fine sharpening for both "Bright" and "Natural".
I still do very much like my K-5 cameras, especially the K-5 IIs. Still very fine imaging and speedy control set. I employ what I need at the time.
09-03-2017, 01:12 PM - 1 Like   #20
I did upgrade from K-30 to Kp, and the arguments for me was more than the better image quality, like:
* Mobile connectivity with Wifi sharing to be able to do quick uploads to internet etc without going through a computer.
* Way better dust removal on sensor than K-30. On the K-30 I had to erase spots from dust every now and then, but that problem is almost gone entirely with Kp (like it does with K-3 II as well).
* Way better AF performance. The Kp actually can follow targets like runners, cyclists and children quite easily, especially with the PLM 55-300 which is not supported on the K-30.
* Better UI with more dials, e.g. to have one dial for aperture, one for shutter speed and the third one for ISO.
* New Possibilities with Astrotracer (but on the Kp you must also have the O-GPS module).
etc... I can easily recommend going from K-30 to the Kp!
09-03-2017, 10:35 PM   #21
seagas's Avatar
LOL, well thank you! I'm am a bit busy as I'm already involved with 16 other companies currently, none of which am I the CEO
4k, camera, comparison, dslr, ii, image, images, k-3, k-30, k-30 aperture block, k-30 to k-p, k-3ii, k-5, k-p, lens, mode, mp, photography, wife
K-3II firmware - anyone know what is fixed? victormeldrew Pentax K-3 & K-3 II 64 11-27-2016 04:36 PM
Anyone tried the Sigma 35mm f1.4 Art on the K-3II? schnitzer79 Pentax SLR Lens Discussion 13 05-17-2016 10:10 PM
Low light performance improvement; K-3ii over K-30? Newtophotos Pentax DSLR Discussion 6 11-04-2015 06:32 PM
has anyone upgraded from windows 8.1 to 10? Aaron28 General Talk 48 08-17-2015 01:26 PM
Has Anyone Upgraded Their PC... tabl10s Pentax K-3 & K-3 II 35 01-18-2014 10:10 AM
All times are GMT -7. The time now is 11:28 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
