Originally posted by D1N0 I am calling the use of the term 5 axis stabilisation BS. get somebody to look at your toes. They are obviously unpractically long!
First: does it make sense that a camera can measure 3-axes of rotational vibration or shake (pitch, yaw, and roll) and correct for them by moving the sensor in 3 axes (up, down, roll)? That's 3-axis SR system, right?
Second: if a next-generation camera also measures up/down, left/right linear vibration or shake (an additional 2 axes of motion X,Y) and then uses distance and focal length to correct for that, too, then isn't that properly called a 5-axis SR system?
What do you call a camera that measures 5 axes of shake motions (pitch, yaw, roll, X, and Y) and corrects for them?
