08-22-2008, 07:36 PM   #1
Help for novice
I have a 2 year old istD and am having an intermitant problem with a lens. I am a novice so be gentle.
On some occasions when I try to use my Sigma 70-200 lens the camera will not work. The back panel will flash and the lcd display on the top will show the number of photo's available. In the display Av -- -- flashes on and off. The AF will not work nor can I get the camera to take a picture. When I install my regular lens the camera works fine. Am I changing some setting or button when removing or installing the lens that is causing this? I don't want to send in for repair if this is the case. Hopefully it is something stupid I am doing to cause this. For examole I used the camera and lens last Sat and when I installed the lens to use Sun it will not work. Thanks for any help.
08-22-2008, 07:45 PM   #2
Damn Brit
Guest
Make sure the lens is on the A setting, it's easy to change the setting when removing or attaching the lens.
08-22-2008, 07:49 PM   #3
Thanks for the quck response. I warned you I was a novice. How do you set lens to A ?
08-22-2008, 07:56 PM   #4
Damn Brit
Guest
Look on the lens closest to where it attaches to the camera you'll see it.
08-22-2008, 08:02 PM   #5
Thank you! Thank you! Thank you! I figured it had to be something simple but beyond my recognition. I have been bothered by this for months. Thank you again
08-22-2008, 08:30 PM   #6
Damn Brit
Guest
No worries, glad I could help. I've done it a few times myself and now I know straight away that I've done it.
08-22-2008, 10:18 PM   #7
Moved to the DSLR forum.
08-23-2008, 02:36 PM   #8
rfortson's Avatar
QuoteOriginally posted by Damn Brit Quote
Isn't that the truth? I've done it twice I think, and I always get the "hot" feeling in my gut thinking that my precious has died on me. Then I get that relieved feeling when I remember the aperture ring.
camera, display, dslr, lens, novice, photography
Novice need help. roscopecotrain Troubleshooting and Beginner Help 11 10-18-2010 07:55 AM
A new K-x for a novice wench.weber Welcomes and Introductions 3 02-28-2010 08:18 PM
Blackpool by a novice :) grunty Post Your Photos! 5 09-04-2009 02:55 PM
K20 to much for a novice? luckyrabbit Pentax DSLR Discussion 35 01-06-2009 01:06 AM
All the Initials confuseing to a novice steven smith Troubleshooting and Beginner Help 7 06-04-2008 08:37 PM
All times are GMT -7. The time now is 02:13 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
