Originally posted by Tigs I received the monopod today and did some tests with the K-70 and DA 50-300 WR
The goal was to see which combination produced less shaky images.
Shutter speed was set to half a second and focal length set to 300mm.
Conclusions:
- SR definitely helps reduce motion blur while used with a monopod.
- The camera automatically disables SR while panning and automatically enables SR when the monopod is more stable.
- The less to the most shaky technique based of 10 pictures (each technique) of the same subject:
1. Monopod, SR on
2. Hand held, SR on
3. Monopod, SR off
4. Hand held, SR off
The difference between using a monopod vs hand held is not very big but the results were still clear.
I imagine the effect of using a monopod would be more significant on a long day of shooting and with heavier lens and camera.
can you confirm what camera you were using when testing?
any body got any thoughts about whether such results would be transferable to another camera body
I have a K 3 and K 5 II and do not know what type of SR systems are in either camera
I have used the K 3 and K 5 II with the D FA 150 - 450 mm hand held trusting the SR to help and it does
I have used the K 3 with the D FA 150 - 450 mm and the D FA *70 - 200 mm F 2.8 hand held trusting the SR to help and it does
