09-20-2017, 05:39 PM   #1
pentax360's Avatar
Are metal K lensmounts aluminum or Stainless steel?
Are metal K mount lensmounts on lenses and bodies aluminum or Stainless steel?
Why I want to know is I was testing my new 3rd party KAF lens, and found out catch in focus isnít possible without a workaround.
People use aluminum foil, to short the pin, but I thought thatís a bit rinky dink, and prone to shredding, so I tested out feeler gauges and a 0.04mm one works well.
The thing is aluminum is soft, so if the lens mount is made of it I don't want to erode it using a brass feeler gauge.
Thanks
09-20-2017, 07:30 PM - 1 Like   #2
dcshooter's Avatar
Neither. They are chromed brass.
09-20-2017, 08:15 PM   #3
QuoteOriginally posted by pentax360 Quote
Why I want to know is I was testing my new 3rd party KAF lens, and found out catch in focus isn’t possible without a workaround.
CIF does not work with AF lenses except for those that have in-lens focus motors and an on-lens on/off switch. With that switch in the "off" position and the switch on the body in the AF position, CIF may work. Again, CIF generally does not work with AF lenses.
09-20-2017, 10:53 PM   #4
QuoteOriginally posted by dcshooter Quote
Not all, it depends.
09-21-2017, 06:16 AM   #5
dcshooter's Avatar
I should clarify. All Pentax-made K mount lenses and bodies have chromed brass mounts.
Third party lenses with black mounts typically use anodized aluminum. Anything silver on a third party lens is nearly always going to be chromed brass as well. Stainless steel is not used as it is harder to machine, more expensive, and causes undue wear to the camera side bayonet. I've seen a couple of lenses with silver toned anodized aluminum bayonets, but that's literally one or two out of thousands.
10-01-2017, 12:17 AM   #6
pentax360's Avatar
Thanks, just what I needed to know.
10-01-2017, 12:29 AM   #7
Sandy Hancock's Avatar
Yeah, but what would you know?
aluminum, camera, dslr, feeler, lens, lensmounts aluminum, metal, metal k lensmounts, photography
Stainless steel mesh covering jbarry Monthly Photo Contests 0 10-07-2014 04:45 AM
Machinery Stainless Steel Thunderbird bucfan1234 Post Your Photos! 8 12-17-2013 01:53 PM
Macro Stainless steel pkeric054 Post Your Photos! 1 07-01-2013 02:09 PM
Magnesium chassis vs. polycarb/stainless steel body? sahale Troubleshooting and Beginner Help 23 06-02-2012 10:32 AM
Misc Stainless steel pkeric54 Post Your Photos! 2 03-01-2012 03:19 PM
All times are GMT -7. The time now is 03:27 PM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
