Originally posted by Na Horuk The idea of a digital focus limiter has been discussed before, but I don't think this is possible at the moment, as the camera doesn't really know where it is focusing. It just keeps going until it locks focus or gives up.
Maybe it could be done, but Im afraid it would need more than a firmware update.
If the AF system knows which way to drive the lens focus mechanism, then it doesn't need to know where the current focal point is. Presumably, it will continue providing a signal to drive focus in one direction or the other, until the sensors indicate that focus on the subject has been achieved. If that's the case, it may not be possible to provide this feature without a hardware component of the lens that provides position data. In theory, I suppose the AF system could drive the focus from one stop to the other, using a pulse count on the drive motor (which I assume is a stepper type) to determine those points, and then allow the user to select a band of movement at either end, but I don't know what else would be required to make this work satisfactorily.
