10-19-2017, 05:05 PM   #1
Sluggo's Avatar
K20D stubborn memory card door
Just wondering if this is common: my K20D bodies (a pair used for stereography) both have memory card doors that are difficult to open. When I twist the latch, usually nothing happens. Sometimes if I sit and wait for a few seconds the door will belatedly pop open. Lately I've had to use the thumbnail on my other hand, which is a little hard to get into that tiny crack. I haven't yet resorted to prying with a jeweler's screwdriver but might have to before long.
Once the door is open, I can tell that the hinge turns freely, and the spring doesn't seem weak. My guess is the weather seal has become a little gummy with age. If that's correct, what's the sensible approach - just try to dig the stuff out? I'm tempted to brush a little talc around the perimeter of the opening but don't like the idea of any of that eventually migrating into the SD contacts.
A point to add - when I put the card back in and close the door, it's easy to open for a while. This seems to indicate there's no problem with the latch. It only becomes difficult to open when the door has been closed for hours or days. Again I think this is consistent with sticky seals. Or what other causes could there be?
10-19-2017, 08:33 PM - 1 Like   #2
E-man's Avatar
I have the same problem with my Samsung GX-20, which is a clone of the K20D, but not with my K10D. I can get it to work properly for a while by spraying the latch mechanism down with electrical contact cleaner but the fix doesn't last. On mine, it appears the latch itself is sticking a little. I've actually perfected a technique for opening the door one-handed by gently prying with my little fingernail while twisting the latch with my thumb and forefinger. The amazing thing is I'm doing this with my right hand and I'm left-handed.
10-20-2017, 12:10 AM - 1 Like   #3
Arjay Bee's Avatar
O ring decay - goes all gummy - I work around it by using the same techniques as above. But the O ring under the Exposure hold button on my camera is also sticking now - which is annoying as it doesn't free up and is under the button. Grrrr.
10-20-2017, 04:52 PM   #4
Sluggo's Avatar
Blundering around the web about sticky door seals on other product forums other than cameras turned up some references to talc, some to silicon spray, some to cleaning with alcohol. I tried using isopropyl alcohol with a q-tip on one of the cameras, and the rubber bit almost instantly disintegrated to powder. It's a very thin seal! So I dug out what little was left and tossed it. The only true repair would be a new seal, but honestly these cameras are old and I don't use them with WR lenses anyway; I'd like be able to open these doors without the hassle for the remainder of their lives, so will probably ditch the other seal too before long if the first one keeps behaving.
11-08-2017, 04:32 PM   #5
cardinal43's Avatar
My 6 year old K20D does the same thing. I feel like I'm going to break the latch off. It will always open after a little bit of jiggling it.
11-09-2017, 08:23 PM   #6
Sluggo's Avatar
Oh yeah - I should follow up here to confirm that removing the door seal (just digging it out with a tiny screwdriver or whatever) ends this annoyance: turn the handle and the door pops open consistently and immediately. Full WR is sacrificed of course.
Anybody who removes the seal should make sure that end of the camera is facing downward while doing it, so gravity doesn't send bits of decrepit rubber into the card slot.
camera, card, door, dslr, k20d, k20d stubborn memory, latch, memory, memory card, photography
SD card does not click in place and Memory Card Error barbriba Visitors' Center 2 05-03-2017 05:17 AM
Sticky memory card door on Samsung GX-20 (K20D clone) E-man Troubleshooting and Beginner Help 8 02-27-2017 05:00 PM
SanDisk memory card works on PC but says 'memory card error' in K-S2 kudzx Pentax K-S1 & K-S2 9 02-15-2017 09:03 AM
the knob to open the SD card door broke off K20D wolvesrule Troubleshooting and Beginner Help 11 08-27-2016 12:56 PM
K-5 Memory Card door broke, where or how to fix? pentaman Pentax K-5 9 04-17-2014 11:02 AM
All times are GMT -7. The time now is 05:16 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
