Originally posted by stevebrot I believe there is a misunderstanding. The f-number designation is not the minimum usable aperture diameter. It is the maximum aperture (exit pupil size) that can be addressed in full by the virtual aperture of the sensor. The sensor can still detect coincidence, just with less precision than what the lens may offer. The minimum aperture, OTOH, is usually one to a few stops narrower and represents the threshold for "blackout" below which the detector is "blind"*. For the f/5.6 sensors, that point is reached somewhere between f/8 and f/11**. When approaching the minimum, the detector will work, though with lower efficiency. Since the f/2.8 points incorporate both f/2.8 and f/5.6 detectors, it is difficult to know where the actual minimum is for the f/2.8 component is. I would expect it to be narrower than f/4 and that the system uses output from the detector with the best signal.
* This is strictly analogous to blackout with split-image and microprism focus aides in the traditional focus screen. FWIW, the split-image in the better screens are designed to be sensitive to f/1.4 with blackout at about f/8. A microprism focus aid is generally sensitive to somewhere between f/2.0 and f/2.8 with blackout around f/5.6.
** My K-3 is unable to AF at narrower than about f/9
Here for a refresher of PDAF:
How Phase Detection Autofocus Works
The thing is basically, the sensor is composed of 2 sensitive parts and measure the amount of dephasing between the 2 parts. The key question is the distance you put between the 2 parts of the sensor. If the distance is quite narrow, the difference in signal will be small or not visible at all. But it will work with a quite narrow lens apperture. If the distance is quite large, the difference in signal will be large but if the lens has too narrow apperture, the defocussed light ray will not be visible at all as the lens simply do not transmit them.
It is not by random that f/5.6 is the basic AF point apperture and that the slow lenses are also f/5.6 (Pentax has actually and f/5.8 lens but that's near enough f/5.6). If is true that you may make the AF to work up to f/8 or f/9, but then the performance is quite unreliable and bad and work only in some case. Lot of light, huge constrast and so on.
You bet that at f/3.5 the f/2.8 sensor that is then mostly blind due to a too narrow apperture would perform better than the f/5.6 sensor that is less precise but has then a perfect signal to analyze. I'am sure that you right, there likely an apperture narrower than f/2.8 where the f/2.8 sensor would still perform better than the f/5.6 sensor. For me this may be f/2.9 or f/3. For you that may extends to f/3.5 or maybe f/4 or f/5.
In the official documentation the f/2.8 sensor if for lenses with f/2.8 as max apperture or faster and f/5.6 for lenses with f/5.6 max apperture or faster. They no official support for anything slower and this show for example on AF compatibilities when using the 1.4 TC. Pentax consider that using the TC on any lens that make the system having a max apperture smaller than f/5.6 will not AF properly. I take the same assumptions.
