Originally posted by jeryst So, at current prices, the K-1 is about twice the price of a KP, or to put it another way, for the same
amount of money, you could buy 2 KPs or 1 K-1.
I know I am over simplifying this, but is the K-1 twice the camera that the KP is?
If not, how can anyone justify buying a K-1?
What mean twice ? The KP overall is smaller/lighter and take smaller/lighter lenses for the same framing. The lenses are also also often less expensive too. The KP is better for somebody that favor light/small and want to spend less overall than the K1.
The K1 provides more resolution but also more typically used with very expensive, heavier lenses that perform better. Focussing on the difference it allows for more subject separation, has better low light performance and tend to better leverage the sweet spot of the lens used. The question is more what is "good enough". With the proper investment the K1 will provide satisfying image in a few more cases than the KP on top of providing a more satisfying photographic experience if you focus only on that.
The Kp will provide a less obtrusive experience, being a lighter/smaller overall but there will be a few more case where the image will not be good enough.
Both are more than good enough for fantastics shots, large print and all (and ask yourself how many large print like 30x40" you'll have in your home for show !!!). What will make for an interresting photo is the subject, the light, the composition, the right moment, the photographer technique first rather than the gear.
And speaking of KP, you can also buy a K3 or K3-II that have almost the same set of feature and cost significantly less. They are older bodies so come with some limitations (like worse high iso performance) but also benefit like "pro" level feature like 1/8000s max shutter speed or 2 SD card support.
Whatever you choose you'll be able to shoot fantastics photos as long as you also get the proper lenses. The lenses are actually often more important to the final outcome than the camera and they keep their value longer.
If you are a beginer, I'd go for something cheap/basic, in particular for the camera body and some not so expensive lens. A used K3 or a new K70 shall be more than enough, coupled with a sigma 17-50 + Pentax 55-300, you should have something not so expensive to start with ($1300-1500 total), maybe around $1000 if buying everything used. That should sell back well without much money loss if you don't like it or want to change gear and also be capable enough to cover many situations.
Remember that the most likely outcome is that you'll grow bored or get only quite average photos (or even bellow average photos) not due to the gear, but to yourself. You may not like the practice that much, pratice enough or simply not be a natural with it, maybe not having the artistic fiber for it. In all theses cases it is certainely not worth it to spend too much on it and you can't really know in advance so if you are a beginer I'd avoid buying the K1.
