11-24-2017, 09:01 PM   #1
Alnjpn's Avatar
Recommended backup body
Hi, I am looking for a backup body to complement my K3. Secondhand bodies currently in my price range are the k5iis, ks2, k3 or k70. Which would you recommend?
It will be used mainly for hiking, landscape and travel.
Any thoughts greatly appreciated, thanks
11-24-2017, 09:05 PM - 1 Like   #2
If you got the K-70 you'd probably want to make it your main body for the IQ. But in any case go for that or a second K-3, IMO.
11-24-2017, 11:01 PM - 1 Like   #3
Alex645's Avatar
Any back up is better than no backup. But if you have a choice, and it's truly a backup, another K-3 makes the most sense because if you need to grab it, everything is where you expect it to be and the sensor will match your primary K-3.
If price wasn't a factor, I'd suggest getting a KP and then using your K-3 as the back up.
11-24-2017, 11:33 PM   #4
hcc
hcc's Avatar
+1 with Adam.
A second K-3 would be the ideal setup IMHO. You could mount different lenses on both K3s, and interchange them (rather than change lenses). Using two identical bodies does reduce the risk of errors IMO.
I have to admit that my backup is my old K-7. Thankfully the setup is close to the K-3 (same body structure). But I ted to use different settings to compensate for the lower ISO (especially) and resolution of the K-7.
My 5 cents.
11-24-2017, 11:57 PM   #5
QuoteOriginally posted by Alnjpn Quote
Get a K3. I have K1 and picked up a K5IIs as back up. I regret doing that because the camera is so slow compared to K1. I should have picked up a K3 which is much faster in every respect. BTW, I previously owned both K5IIs and K3. Image quality of the K5IIs is fantastic but the camera is so slow and not in the same league as the K3. If I had the budget, I would pick up a KP as Alex645 suggested.
11-25-2017, 12:08 AM   #6
have you thought about getting backup lenses in case some lenses would fail?
11-25-2017, 12:30 AM   #7
K3 if you don't want to hunt for dials, buttons etc.
K70 if you want a lightweight camera with excellent image quality.
11-25-2017, 02:09 AM   #8
Alex645's Avatar
Not sure if you're being serious, but I believe the OP has mostly primes and a zoom that covers the entire range of those primes. From experience, I've had a couple zooms "fail", but (knock on wood), never a prime. And in a pinch, the OP can use a shorter focal length and crop.
Also getting a back up Pentax lens in Osaka isn't a problem as it might be in Vienna or Honolulu.
11-25-2017, 03:44 AM   #9
D1N0's Avatar
As I never sell anything my back-up is always my old camera. I even have a back up for that one. the one before. From the Camera's you mention the K-70 is the best choice, but you run the risk you'll not want to use the K-3 any more. So instead get a K-1 and use the K-3 as your back-up .
11-25-2017, 04:07 AM   #10
Yes I am being serious. Lenses can fail as much as camera bodies and perhaps anything with motion of mechanical parts could fail over time. Camera electronics can fail from mechanical stress as well while typically electronic components are qualified to last at least 11 years (according to standards), except non volatile memory that is rate with number of R/W cycles.
---------- Post added 25-11-17 at 12:09 ----------
Yes, I agree. Although I found Pentax products to be well present in Vienna.
11-25-2017, 05:34 AM   #11
QuoteOriginally posted by D1N0 Quote
Read the original post, please. K-1 is not in OP's price range.
11-25-2017, 05:57 AM - 1 Like   #12
Alnjpn's Avatar
Thanks everyone for your thoughts and comments. I am going to keep my eyes open for a secondhand K70. Second hand models are getting more common here, and coming down in price. I am looking forward to seeing the IQ and having a play with a new camera. Plus being slightly smaller and lighter will be beneficial for hiking. Thanks again for your help!
11-25-2017, 06:41 AM   #13
jddwoods's Avatar
My experience: Camera bodies, K-10D, K-5 and K-3, no failures all of them work as good as they always did. Lenses: HD DA40 Limited, failed, repaired under extended warranty, DA 17-70, SDM motor failed just too expensive to repair and manual focus it too tedious to be useful with this lens. You have a point here, lenses can fail.
Regarding the original post, the K-5 is my backup to the K-3 but at some point I would like to replace the K-5 with something newer and able to use KAF4 lenses and the K-3 would be the backup to that. I have passed the K-10D on to my son.
My two cents of thought, a second K-3 would make sense to me if you have a mix of large, heavy lenses and small light primes. Two K-3 bodies, one with grip, and large lenses, and one, no grip with small primes and all use the same batteries.
11-25-2017, 08:07 AM   #14
QuoteOriginally posted by jddwoods Quote
Exactly the same for me: same bodies, same lenses, same lens failures :-)
11-25-2017, 09:49 AM   #15
csa
csa's Avatar
Currently I use a K3, with my K10D as a backup. Down the road, I'd like to get a K70, and use the K3 as backup.
As far as backup lenses, in case of failure, I think most of us have other lenses that would get us thru losing one. If you don't have a backup body, and experience a failure, dropping it, etc., then what good are all the lenses in the world?
backup, body, camera, dslr, k3, pentax, photography, vienna
Is there a backup body for the K3ii? Johnontheroad Pentax K-3 & K-3 II 30 06-26-2016 10:53 AM
K-01 as compact backup/second body to K30? gerax Pentax K-01 3 08-29-2015 03:07 AM
K-01 as backup body / for video Pheo Pentax K-01 7 01-02-2013 11:52 AM
Q as backup body brofkand Pentax Q 6 02-08-2012 07:11 PM
People Being the backup-backup photographer Rory Post Your Photos! 5 10-03-2010 08:43 PM
All times are GMT -7. The time now is 01:59 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
