Today I got a problem with the original pentax adapter.
Was using on a lunch time with a paragon 500mm f8 on k200d, and when tried to unscrew not only the lens (lens got stuck with adapter as it seems) but also the adapter got out from camera.
Now when I tried to use the adapter it just doesn't lock on the camera. Seems it work like I add removed the lock pin / spring clip from the adapter.
Any ideas ?
(Have to see how I will unscrew the adapter from the lens...)
