Originally posted by The Squirrel Mafia If your looking for the best image quality out of those 3 bodies, the K-70 is it. It's a bit better than the K-5IIs & K-3II. The K-70 is basically an updated K-5IIs, but without the "pro" build. It has the same autofocus system that the K-5IIs has, plus some other newer features.
The K-5IIs is a slightly older camera, but pretty much the camera that a lot of Pentax users measure other Pentax cameras to. The only downside is no future KAF4 support. The K-3II is the fastest performing APS-C camera & it's built like a tank. There's a supposed K-3II replacement due sometime next year which should have all the features that the K-3II has, plus improvements, but it's probably going to be pricey.
EDIT: These are processors not focusing systems sorry for the sidebar - brain glitch!
K-70 uses Prime M II
K-5iis uses Prime II
K-3 uses Prime III
KP uses Prime IV
K-1 uses Prime IV also
K-50 uses Prime M
It is hard for me to recall but I thought the Prime M was itself an update to Prime II. How Prime M II compares to Prime III or IV I am unclear on.
What the differences are - who knows.
---------- Post added 12-07-17 at 03:01 PM ----------
Focusing systems:
K-1 = SAFOX 12, 33 focus points, 25 cross type
KP, K-3, K-3ii = SAFOX 11, 27 focus points (25 cross type
K-70, K5iis = SAFOX X, 11 focus points (9 cross type)
K-50 = SAFOX IXi+, 11 focus points (9 cross type), diffraction lens, wavelength sensor
According to this the focusing systems of the K-3, K-3ii and KP are the same and superior to the K-70 or K-5iis. The K50 is actually a lower type but has a few tricks tossed in over the K-5iis... and still a lower overall number so presumably not quite as good. K1 > K-3/KP/K-3ii > K-70 > K-50
On top of this the metering ranges are different the K-70 is a 0-22 EV metering system, the KP, K-3ii etc are -3-20 EV systems. Not sure how this translates in practical terms for most of us.
Finally the metering sensor is 86,000 points on the K-3, KP, K-3ii etc. whereas the K-70 only has a 77 segment sensor.
All are purported to focus from -3 EV to 18 EV by the way.
(Accuracy will vary)
---------- Post added 12-07-17 at 03:13 PM ----------
Here's a nice side by side comparison:
Pentax KP Review - Specifications | PentaxForums.com Reviews
K-3ii, KP, and K-70
