12-14-2017, 04:18 AM   #1
Neville's Avatar
Lens not connecting properly to camera
I have a Pentax K-5II and I am having a problem when I attach my Pentax smc f/1.7 50mm lens to the camera.
I cannot auto focus or adjust the aperture. Is there a faulty connection? I donít have a problem with any of my other lenses.
12-14-2017, 04:48 AM   #2
hcc
hcc's Avatar
I would suggest first to check the lens contacts, If all other lenses work on your K5ii, the issue must come from your FA50mm f1.7.
Maybe a bit more info could help: is the lens loose or hard to lock? Have you an opportunity to mount the F50mm f1.7 on another Pentax dSLR?
My 5 cents... since I do not have either a K-5/K-5ii or F50mm f1.7.
12-14-2017, 04:59 AM   #3
twilhelm's Avatar
This will happen when the contacts on the camera and/or lens get dirty. Clean them with a pencil eraser, or what I do is use a q-tip with a bit of isopropyl alcohol.
I’ve had this happen often with lenses I buy from e-bay.
12-14-2017, 05:01 AM   #4
Neville's Avatar
QuoteOriginally posted by hcc Quote
I've wiped the contacts on the lens with a dry cloth, but that does not seem to help.
The lens is rather stiff to mount, more so than it used to be when I used it successfully in the past.
Unfortunately I don't have another DSLR to test it on.
12-14-2017, 05:07 AM   #5
Fogel70's Avatar
Have you double checked that the aperture ring is fully locked into A-position?
12-14-2017, 05:15 AM   #6
Neville's Avatar
QuoteOriginally posted by Fogel70 Quote
Yes, that was one of the first things I checked.
12-14-2017, 06:49 AM   #7
Not a Number's Avatar
Unmount the lens and look at the contacts while moving the ring in and out of the "A" position. The "A" pin should extend or retract ever so slightly. If it doesn't, cleaning, adjustment or replacement is needed.
Has the lens been dropped, perhaps by a family member and you were not told? A bent flange could explain why it seems more snug and malfunctioning.
12-14-2017, 06:50 AM   #8
Any signs of physical damage to the mount?
12-14-2017, 07:04 AM   #9
Neville's Avatar
Iím not sure which is the ďAĒ pin, but I did do as you suggested and I donít notice any of the pins moving at all.
Iím not aware if the lens been dropped and it appears to be fine, with no signs of damage.
12-14-2017, 11:14 AM   #10
Otis Memorial Pentaxian
QuoteOriginally posted by Neville Quote
I’m not sure which is the “A” pin, but I did do as you suggested and I don’t notice any of the pins moving at all.
I’m not aware if the lens been dropped and it appears to be fine, with no signs of damage.
The "A" pin is second from the right in your photo. Depending on lens, it may or may not physically retract when the aperture ring is moved off the "A" setting.
The diagram below is for the KA mount. The KAF scheme on your lens adds an additional contact at far left (position 7)
(I used the KA diagram for clarity since it shows all the contact positions.)
It may just be lighting, but the contact at position 1 on your lens does not look right. Did this lens work properly for you in the past or is it a new acquisition?
12-14-2017, 05:49 PM   #11
Right, I forgot. The later 7 pin mounts may not retract the pin. You'll have to check for continuity with a continuity checker or Multimeter.
12-15-2017, 11:21 AM   #12
twilhelm's Avatar
It almost looks like there is debris in pin 1.
camera, dslr, lens, pentax, photography
K-1 not connecting to my phone via wifi geomez Pentax K-1 & K-1 II 24 11-27-2017 01:45 AM
pentax K 30 not connecting to pc without holding it in place.. xcaret Repairs and Warranty Service 6 10-19-2017 12:47 PM
K1 - GPS not turning on/off properly and camera power-on sporadic clickclick Troubleshooting and Beginner Help 4 07-09-2017 07:12 PM
Pentax Flu card not connecting after firmware update LinksProd Troubleshooting and Beginner Help 4 07-11-2016 01:28 PM
KS-1 Kit lens not working properly after using manual lens tortie Troubleshooting and Beginner Help 3 08-30-2015 12:57 PM
All times are GMT -7. The time now is 07:46 AM. | See also: NikonForums.com, CanonForums.com part of our network of photo forums!
